Typhoon, XR6t and XR6 injectors
Page 1 of 2 [ 26 posts ] Go to page 1, 2  Next
 Post subject: Typhoon, XR6t and XR6 injectors
Posted: Wed Jun 06, 2007 11:36 pm
Did a quick search but didn't find too much that was use full.
So couple of questions,
1: Are standard ford Typhoon, XR6t and XR6 injectors from the BF range 32pounds?
2: Are they high or low impedance?
3: What does the standard ECU from an EF 4.0 like to read, High or Low imp. injectors?
4: Can a Wolf3d V4 read both high and low impedance injectors?
5: Will they run fine with a standard rising rate reg.?
All help appreciated Fellas
Regards,
Moody
 Post subject: Re: Typhoon, XR6t and XR6 injectors
Posted: Wed Jun 06, 2007 11:50 pm
Ride: el falcon
Power: 608 rwkw
Regards,
Moody
1: yes xr6t's are 32lb dunno about the rest
2: high
3: high
4: i dont know, but i would think so.
5: yes with a after market ecu
# 1997 EL Falcon GLI - 600+rwkw
# 2008 FPV FG GTE - Xa Coilovers, 20x8/ 20x10 Fairladys
Posted: Wed Jun 06, 2007 11:59 pm
Perfect, exactly what i was looking for, cheers dude :)
On another note, how do rising rate regs. go on the standard ECU? What about with a Flash?
Posted: Thu Jun 07, 2007 10:42 am
Ride: Fordrunner 5.0 Turbo
I think Fritz is your man to answer that as I think he had a rising rate reg and standard computer on his combo in the early stages.
Posted: Thu Jun 07, 2007 6:54 pm
will do, its only going to be for my early stages.
Posted: Thu Jun 07, 2007 10:44 pm
Ride: el falcon
Power: 608 rwkw
u dont have a choice if u are going to use the standard ecu, RRR is a must.
Posted: Thu Jun 07, 2007 10:49 pm
This may sound like a bit of a stupid question, but whats the difference between an adjustable fuel pressure reg. and a Rising rate reg.?
What are some quality brands and models of RRR's to look for and what should I be expecting to pay?
Moody
Posted: Thu Jun 07, 2007 10:53 pm
Ride: AU Fairmont Ghia
an adjustable reg allows you to change fuel pressure, a rising rate reg increases fuel pressure as boost increases.
Posted: Thu Jun 07, 2007 11:56 pm
Ride: el falcon
Power: 608 rwkw
sard, turbosmart. u would need atleast 2:1.
best way would be to run standard injectors and a 12:1 vortex reg, at around standard fuel pressure with a good fuel pump.
Posted: Fri Jun 08, 2007 3:10 pm
should i be expecting many problmes if i go this way?
and where can i get Vortex regs?
Posted: Fri Jun 08, 2007 8:49 pm
Ride: el falcon
Power: 608 rwkw
yes expect problems with timing, and detonation because your car is a ef you cant change base timing.
cappa sell vortex regs i think.
man if u cant afford some sort of tunable ecu then u shouldent be turboing your car.
Posted: Fri Jun 08, 2007 11:00 pm
what did you start with? microtech?
Posted: Fri Jun 08, 2007 11:02 pm
i mite aswell bite it and go the ems 8860 then, from memory 1800 odd dollars plug and play?
there a quality system riught? i know several people with them but anyone on here had any dramas?
Posted: Sat Jun 09, 2007 2:53 am
Ride: eb falcon
turbosmart are 1:1.
EB 4L, 8.4:1, R154, GT4202r, 4in exhaust, Greenslade Engineering exhaust manifold, plenum chamber, 90mm throttle, Garrett W2A cooler, Surecam custom, autronic SM4, Bosch 120lb, Crane HI-6, LX-92, LM-1, Turbosmart Reg, 2x bosch 044, turbosmart 48 gate. 470kw+ @ 18PSI
Posted: Sat Jun 09, 2007 1:11 pm
Ride: el falcon
Power: 608 rwkw
yeh i know they are 1:1 but he asked for good brand's than y i stated atleast 2:1 after that.
It is currently Wed May 21, 2025 6:00 pm All times are UTC + 11 hours
