svo_matt |
Hello all just a quick one,ive got a blown 5liter that is using oil its not leaking any were that i can see,its not going out the back and there is no oil in the warter,this has only starter when i got the top end rebilt(big heads,cam,rockers,and inlet manafold) any help would be appriciated.
_________________ ..My fake plant died because I forgot to pretend to water it.. |
TerroristGHIA |
Did the block off plate for the RPMII go on. It is under the PCV. i didnt fit mine when i first did it and she was sucking oil into the manifold. Good way to check is the runner for No4 and 8 will have oil in them .
Brett
svo_matt |
just had a look brett and an the left up the back there is a small pool of oil sitting inbetween the injectors (small well there) is that what you mean
svo_matt |
{USERNAME} wrote: Did the block off plate for the RPMII go on. It is under the PCV. i didnt fit mine when i first did it and she was sucking oil into the manifold. Good way to check is the runner for No4 and 8 will have oil in them . what is the pcv,were is it
Brett
TerroristGHIA |
PVC is the hose that goes into the back of the inlet manifold at the middle of the valley. To put the plate in, the lower needs to be removed and a restrictor plate goes over the bottom of this hole. A pool of oil near the injectors would lead me to believe that there is a leak at the rocker covers, or a leak between the upper and lower.If it is between the upper and lower then i would assume that it is the missing the restricotr plate
Brett Brett
