postision of oil feed line and drain line
Page 1 of 1 [ 12 posts ]
 Post subject: postision of oil feed line and drain line
Posted: Thu Dec 27, 2007 10:24 am
my turbo is mounted normaly with manifold flange pointing up, but becuase im using a r33 turbo the inlet for the oil feed line is not on the top of the turbo. its more on the side of the turbo and so is the drain line. will the oil still be pumping though fine?
Posted: Thu Dec 27, 2007 10:53 am
Ride: AU2 Ute
Rotate the housings so it is vertical.
Posted: Thu Dec 27, 2007 1:43 pm
but as it is now will it pump through and out? and how hard is it to rotate the houseing?
Posted: Thu Dec 27, 2007 1:55 pm
Ride: AU2 Ute
Its easy.
Just loosen the bolts on the back of the housings and turn them.
Ive read that an angle of 30 degrees from vertical is okay. Anything more is asking for trouble.
Posted: Thu Dec 27, 2007 4:14 pm
Power: 482 rwkw
Keep it as close to vertical as possible with in 5*...
Or you'll have seal issues...
As in ZOOM 126 edition
Posted: Thu Dec 27, 2007 4:59 pm
yer im trying to move the housing now, but dam its hard to move and i don't want to use a hammer because i don't want to damage the turbo. what can i do to make this easier?
Posted: Thu Dec 27, 2007 9:08 pm
Power: 482 rwkw
Spay with WD40 or similar..
Don't undo bolts too much, chances are it would be the turbine housing thats giving you grief...
A sharp hit with brass hammer will do the trick on flange....
If you undo bolts too much you run the risk of damaging the compressor or turbine wheels..
The return hose should be as big as possible and for the first 150mm as vertical as possible so there's no chance of oil backing up inside...
Posted: Thu Dec 27, 2007 9:48 pm
dont think the nissan turbo will rotate, im pretty sure they have a little pin in them from it rotating....like the IhI subaru turbos....
4LTR-JET: 9.1 @150mph!!
Posted: Thu Dec 27, 2007 10:08 pm
Power: 482 rwkw
Ah yea try the other way.
Posted: Fri Dec 28, 2007 2:15 pm
which way is the other way?? how do i remove the pin?
Posted: Sat Dec 29, 2007 7:34 pm
Ride: EB GLi 4.0L
Internally wastegated turbo's require that the compressor cover and exhaust cover remain aligned because the actuator for the wastegate bolts to the inlet and connects to the exhaust but you should still be able to rotate the core. I've done it on a few turbo's now and i've had tight/sticky inlets and exhaust so like was said before, try WD40 or similar or what i did was clamp the exhaust flange in a vice and stick a screwdriver in the inlet cover to get some leverage. Obviously don't go nuts with this method if it's REALLY tight because the inlet is only alloy.
EBII 4.0L GLi | T5 | 3.27 Spool | POD | KKK K27 Turbo | 600x300x76 FMIC | 40mm Wastegate (dead) | RPD Stg1 Cam | B&M Launch Control | Thermos | 3" Dump | Twin 2.25" Zorst | 197kw@3500rpm, 7psi LEAN!
To Come: Hydraulic Handbrake | Coilover Springs | Fuel Pump | Microtech MT8 | 455cc Injectors
Posted: Sat Dec 29, 2007 11:05 pm
Power: 482 rwkw
Its often due to bolts hitting water cooling flanges...
It is currently Mon May 26, 2025 6:30 am All times are UTC + 11 hours
