What do you think of my turbo setup and any suggestions???
Page 1 of 1 [ 13 posts ]
 Post subject: What do you think of my turbo setup and any suggestions???
Posted: Wed May 21, 2008 7:40 pm
Ride: EF V8 Futura, 180sx
Hey guys i just got my car up and going good today besides the exhaust side of things.
im running 5.5psi of boost into au engine in ef
no name turbo with 1.15 A/R rear and .60 A/R front.
no name 38mm wastegate
log manifold.
Sard rising fuel reg
home made intercooler kit
universal oil cooler
Plans
i do plan on relocating the battery to boot within a week or 2 and moving the pod down into the battery tray.
make up heat shield for turbo manifold and brake master.
you got any suggestions or tips
also
i wanted to know
what fuel pressure do you run for when it idling????
on the blitz bov's whats the top adjustment and what way is what?
bov plum off intercooler piping correct?
Ford EF Futura Black
18" koya Strykers, AU engine with port and polish EB head, crow valve springs, standard cam, Large aftermarket RX7 turbo, T5 manual 3" intercooler piping, 600x300x100 intercooler core, MSII with innovate wideband O2 sensor and guage. BA F6 bodykit
Posted: Wed May 21, 2008 7:41 pm
Ride: Supercharged BA XL ute
Well done champ.
BA XL ute.
P'maker headers',Hi flow cat,3" sports sytem,
Raptor V-clutched lightweight not intercooled,no tranny cooler,no worries.
Posted: Wed May 21, 2008 8:01 pm
Looking good, will be good to see how the no name stuff really holds up!
Posted: Wed May 21, 2008 10:31 pm
Gallery: 5 images
Ride: 1994 ED Ricer
just worried about the 'no name' external wastegate..
Do you have any type of boost cut??(i ask because u dont list if u have an aftermarket ecu)... I have heard lots of no name stuff (including ext. wastegates) fail all the time and you dont want to overboost the engine..
Posted: Thu May 22, 2008 1:12 am
Power: 482 rwkw
The 90* off manifold for wastegate?? Would be better if it was angled 30* for better flow...Make sure main shaft doesn't lock up shut when it gets hot.. Some cheap wastegates can do that ...Cutting compound to clearance bearing is all thats needded on some...
Mounting aircleaner further forward helps too.. You have just started.. I don't mean to be criticle..
I guess stand alone ecu, 42Lb injectors are following ??
As in ZOOM 126 edition
Posted: Thu May 22, 2008 3:11 am
Ride: XR6
Looks like a nice set up.. But i would have to strongly agree with EBXR8380, you would be better off placing your airpod somewere nice and far away fron the hot air that will be produced from the Turbo and exhaust.
Posted: Thu May 22, 2008 7:04 am
Ride: BA Wagon Turbo, Ba Fairlane G220
Good stuff looking real good. Yeah your right BOV plums into you intake side of your intercooler pipe. Just one recommendation I would cover your exhaust side of your turbo with a turbo beenie or something as it will melt everything real fast (mine still melts everything with it on) plus keep under bonnet temp down a bit more. And I would also cover your leads they will melt too. :D
Congo Green Ba Wagon With F6 6 Speed Manual Driveline.
Posted: Thu May 22, 2008 7:25 am
Im on standard ecu right now
im looking at buying some injectors and new walbro pump very soon i got a MSII just need to get coil drivers and few little things before i set that up.
Im ganna get some of that ACL head shield from supercheap and make up a few heat shields this weekend.
I do plan to move pod to where the battery is located with a head shield and put battery in boot.
well im only running a small 5.5 right now so it a bit easyer on the car for now but i will keep a eye on the boost.
what fuel pressure do you guys run???? my can is sucking the fuel like a bloody V16 lol no lies i can actually watch the needle move is i boost a whole road lol.
so it recommended a set of 42Lb injectors???? how far do they boost up to roughtly?
thx jason
Posted: Fri May 23, 2008 1:08 am
Power: 482 rwkw
Check vac hoses to MAP senser ??
You can only run std injectors with std ecu..
I'd go for atleast 30 Lb injectors, Walbro 255 intank fuel pump, good tune with ecu M/S11 .. Yes 42's would be around 270 / 300 rwkw...
Posted: Fri May 23, 2008 10:07 pm
map sensor hose is fine i replaced that and clamped it as well lol
i got a adjustable sard rising fuel reg and i got the fuel pressure set about 35psi at idle right now.
also how are you ment to setup the vacuum lines for bov??? i swear there not working you can hear the turbo back lash so i kinda worryed ive done something wrong.
also on the top of the blitz bov it got a 10mm nut and alan key. dose this adjust the release pressure or something? and if i want it to be more sensative what way do i adjust it?
Thx
Jason
File comment: this is exact same as mine but i got 2 :D
Posted: Mon May 26, 2008 1:34 pm
Ride: anything with a engine
Looks Good. That maniflod looks just like the one my brother made for my EF.
The standard regulator is rated at 270KPA (39psi) base pressure. If you have 35psi at idle then that is more than standrd so you will be running rich.
I would suggest you remove the vacume/boost line that goes from the regulator to the manifold and set the pressure to 39psi then reconnect the vaccum line. This will set the pressure to factory specs and your mixtures should be correct except when you go into boost. I would suggest you wire open the waste gate so it doesn't make boost untill you get the megasquirt fitted.
For those who were concerned about the waste gate failing the megasquirt ecu has an overboost cut feature.
Daniel.
For Sale; EF Plug and Play Megasquirt ECU Package. Includes ECU, adaptor loom, base tune, software.
Posted: Fri Jul 04, 2008 5:15 am
Ride: EL XR6
is that the streetperformance kit? Im looking at them but im concernered about the no name turbo and wastegate.
Posted: Fri Jul 04, 2008 6:48 am
nar home made kit
well the turbo and wastegate have been operation good thats all what i can say
It is currently Tue May 14, 2024 11:31 am All times are UTC + 11 hours
