budget turbo of I6, hoestly what did it cost you???
Page 1 of 4 [ 52 posts ] Go to page 1, 2, 3, 4  Next
 Post subject: budget turbo of I6, hoestly what did it cost you???
Posted: Sun Jan 11, 2009 11:33 am
Ride: 80 series cruiser
long story short i am about to get an ED 4L auto base model, I am thinking about going the forced induction route, but want a honest factual real life cost of what i can safely do for the least money.
thanks,
Rob.
Thanks to Crescent Motors, Liverpool.
Call Joe on (02) 9600 6229.
I dont own a Landcruiser, it's a Maverick recovery vehicle!!!!
Posted: Sun Jan 11, 2009 11:47 am
my ba xt -turbo cost me....
manifold- 300
turbo gt35/40- 1200
intake pipe-140
hotside pipe (from xr6t)- 30
intercooler- 180
3bar map sensor-150
xr6t fuel pressure reg..- 150
flash tuner- 400
60lb injectors -420
walbro intank fuel pump- 130
dump pipe and hi flo cat- 125
oil drain lines water feed lines- 150
a custom tune and dyno time-2000
a few little bits like hose clamps gaskets ect
i fitted everything myself easy as pie tapped my own sump ect
about 5395 if my calculations are correct
i got a 212rwkw and it ran 13.8 at 102mph
if the bar aint bendin your just pretendin
Posted: Sun Jan 11, 2009 12:09 pm
with the prices of stuff now i reckon i could have done it all for about 4200 tuned
Posted: Sun Jan 11, 2009 2:41 pm
Gallery: 18 images
Ride: Envi EF
Considering I've seen several full kits go for <$1250 in the last 3 months (manifold, turbo, dump pipe, fuel pump, cooler, piping... etc)
I'd say you could have a turbo'd E series for under 2 grand.
>>>{DESCRIPTION}<<<
Posted: Sun Jan 11, 2009 3:49 pm
with a time bomb for a turbo at those prices
 Post subject: turbo
Posted: Sun Jan 11, 2009 4:34 pm
Exactly tickford_6
Everyone wants to get out of everything cheaper then it ends up paying more for repairs and whatever else goes wrong instead of paying for the good gear from the start.
Wanted Either Capri/Cortina/XY/XW/XR/XT with tough V8 stroker engine, auto, 9inch, upgraded brakes etc[/SIZE][/size][/color]
Posted: Sun Jan 11, 2009 5:08 pm
Ride: EF f a i r m o n t
Power: 315 rwkw
i spent around 10k on mine.
thats buying snort kit
fixing motor(reco head,water pump blah blah)
ems ecu
paying someone to do all work
piping
injectors
fuel pump
water lines
tune.
if i didnt pay someone to do it and skimped on some things probably could have got away with 6k
1995 EF Fairmont with all the Gear.
Posted: Sun Jan 11, 2009 6:40 pm
thanks guys, the thing im worried about is the cheap kits you see floating around on ebay etc, they seem great for around 2000 but im sure they need a lot more. im not looking to run 11's or anything but i dont want a handgrenade either.
im not sure of my budget yet, but it will be a slow build up over the next year or so.
thanks for giving me an idea.
keep em coming guys.
 Post subject: turbo conversion
Posted: Sun Jan 11, 2009 8:41 pm
A awsome turbo kit that a would buy is from these 2 guys. Awsome work at a good price for what your getting.
DO IT ONCE, AND DO IT PROPERLY :D
http://www.calaisturbo.com.au/showthread.php?t=84707
http://www.calaisturbo.com.au/showthread.php?t=107445
http://www.calaisturbo.com.au/showthread.php?t=50987
Plenty of information in the thread and u will quickly notice that the extra money is well worh it. Not only will it perform alot better, its durable, reliable, it lasts and also looks alot better.
Posted: Sun Jan 11, 2009 9:19 pm
Gallery: 18 images
Ride: Envi EF
Not necessarily.
An AIT kit sold for 1250.
>>>{DESCRIPTION}<<<
 Post subject: turbo kit
Posted: Sun Jan 11, 2009 9:39 pm
I would consider the first 2 kits
kits are available at competitive rates including
600hp garrett gt3582r,tial44mm wastegate and manifold $3295
800hp garrett to4z, 44mm tial wastegate and manifold $3600
1000hp garrett t51r 48mm turbosmart wastegate and manifold $4100(add $200 for turbosmart 50mm gate)
1000hp garrett gt4202r 48mm turbosmart wastegate and manifold $4100(add $200 for turbosmart 50mm gate)
I would rather pay triple the money and get brand new gear with warranty and will out perform AIT kit.
Posted: Sun Jan 11, 2009 10:04 pm
Not necessarily.
New? if not..........time bomb
I've got an AIT kit on my patrol, i wouldn't buy another one.
Posted: Sun Jan 11, 2009 10:08 pm
Gallery: 18 images
Ride: Envi EF
Wahhh time bomb.
So every 2nd hand turbo is a time bomb? Every 2nd hand kit is a time bomb? FFS they dont sell for much second hand because the s**t not that expensive to start with.
If you want new you can buy a kit from Snort for <$4k with pretty much everything you'll need (other than ECU).
>>>{DESCRIPTION}<<<
Posted: Sun Jan 11, 2009 11:33 pm
Gallery: 25 images
Ride: FALCON EB TURBO, EL XR6
The thing is, once you start, and if your happy, you won't stop. Which = a big money pit.
Either that or you will give up and sell the s**t for 3/4-1/2 the price you payed for it.
Doing it for under $2000 ain't gona happen.
FALCAHOLIC
IF AT FIRST YOU DON'T SUCCEED
DESTROY ALL EVIDENCE THAT YOU EVEN TRIED
Posted: Mon Jan 12, 2009 6:58 am
Ride: 1993 EB XR8
EFFalcon did his initial turbo build for <$2k and only upgraded chasing a fueling issue
Users browsing this forum: Google [Bot] and 7 guests
It is currently Tue Jun 24, 2025 1:31 pm All times are UTC + 11 hours
