BA INTERCOOLER PIPING ON AN AU TURBO?
 Post subject: BA INTERCOOLER PIPING ON AN AU TURBO?
Posted: Fri May 07, 2010 9:25 pm
Ride: AU XR6
Would Ba intercooler setup fit and work on a turbo AU?
 Post subject: Re: BA INTERCOOLER PIPING ON AN AU TURBO?
Posted: Fri May 07, 2010 11:19 pm
could probly be made to fit, but would need to modify the pipes to suit the different turbo position, and you would need the entire kit. even then you would need to hack up the AU a bit also.
the engine is also a different shape and size.
at the end of the day, you could probly do better for cheaper anyway
mild engine, EL ECU & J3, HI6 & MSD coil
in the shed - .595" lift cam, GT4202, forged AU engine, ems 4424 ecu, glide & 5500 stall - next-bellhousing
{DESCRIPTION} - DOHC BA XR6 engine, T5, AU3 ECU, J3 chip, wideband & logger, ported BBM, 3" intake
Posted: Fri May 07, 2010 11:54 pm
Ride: AU XR6
yeh I was sorta thinking that myself. thanks pal
It is currently Tue Jun 24, 2025 9:32 am All times are UTC + 11 hours
