Tailshaft bolts keep coming loose
Page 1 of 1 [ 7 posts ]
 Post subject: Tailshaft bolts keep coming loose
Posted: Mon Mar 12, 2012 5:31 pm
Gallery: 40 images
Ride: EF GLi/Ghia bitsa
Hey, the tailshaft bolts on my XF keep coming loose, repeatedly, particularlly after I do some towing with the car, Any tips to prevent this happening in future? It has a T5 manual and a 2.77 disc LSD diff if eithier of those things make any difference, although I"m sure they wont.
Gab
 Post subject: Re: Tailshaft bolts keep coming loose
Posted: Mon Mar 12, 2012 5:35 pm
Ride: 2.0 Turbo VW
Power: 142 rwkw
Replace the bolts and use Locktite.
Posted: Mon Mar 12, 2012 6:48 pm
Ride: EL XR6
Ive used my old bolts a few times, never came loose . Flog them up with a hammer and ring spanner and use red loctite.
El XR6 Turbo
Dark Agents,Sunroof, bilstein shocks, 6000k HIDS, 329 mm slotted rotors, twin pot calipers , Climate Control, GarrettT04 turbo,log manifold, crow turbo cam, microtech lt10c, 42lb injectors , 044, surge tank , T56 , rebuilt bottom end , alloy plenum .
Aiming for 300 rwkw
Posted: Mon Mar 12, 2012 6:59 pm
Ride: AU XR8
being xf it will have the little 1/4" bolts and the little half moon braces...
i had this problem in my old ea, loctite and new washers did the job....
Posted: Mon Mar 12, 2012 8:22 pm
Ride: AUII XR6 Uterus
Inbalance or vibration contributes to this also.
Posted: Mon Mar 12, 2012 11:12 pm
Power: 144 rwkw
Loctite should do the job, but as mentioned above, imbalance/vibrations can cause the bolts the undo themselves prematurely.
Loctite blue is good enough IMO.
phongus = Post whore 2006
Posted: Mon Mar 12, 2012 11:57 pm
Gallery: 40 images
I'll pick up some new bolts this week and get some loctite, cant really go too nuts tigtening them because as mentioned they are the small 1/4" thread 11mm head bolts with the U clamps, so cant go stupid on em or they'll break leaving further problems, other than that, I reckon it might be time to get new unis and get the shaft balanced.
Gab
It is currently Wed May 21, 2025 7:37 am All times are UTC + 11 hours
