250 xflow injection
Page 1 of 1 [ 2 posts ]
 Post subject: 250 xflow injection
Posted: Tue Apr 02, 2013 12:23 pm
Gallery: 21 images
Ride: EF, Magna, R33 skyline
Hi guys I have been playing with the idea of building a race car and every one I see is running a carby and would like to know why?? the rules are pretty much open to do what ever. only thing is your not allowed to dry sump... and the carby can be no bigger than 350cfm and the intake has to remain stock looking... I think the biggest let down to the XF efi is the airflow meter. but I can run a aftermarket ecu so I don't have to run that anymore.. I'm thinking of doing this to the motor..
lighten the crank ( i have done it before and have taken about 10KG off )
bigger sump
40thou over pistons
deck the block
and take as much as i need off the head to get to 11.1 comp
take the ports out go 351W valves
double valve springs
3/8 push rods with rolla rockers
electric water pump and fan
custom extractors and 3" exhaust
XR6T injectors
Sard fuel reg
044 pump
3/8 fuel lines
EMS 6860 ECU
just asking peoples thoughts and why are people using a carby if you can only go to 350cfm???
 Post subject: Re: 250 xflow injection
Posted: Wed Apr 03, 2013 1:04 pm
Ride: 93 ED sedan
Power: 161 rwkw
Because it's cheaper.
http://youtu.be/jJTh9F3Vgg0
Users browsing this forum: No registered users and 22 guests
It is currently Mon May 26, 2025 11:41 am All times are UTC + 11 hours
