smartlock problems
 Post subject: smartlock problems
Posted: Wed Jul 03, 2013 9:09 pm
Ride: 96 ef xr6
hey guys i need help with my smartlock car wont start i know if i leave it for half an hour it will start but when i turn it of again same problem is there a quick way of fixing this ????
 Post subject: Re: smartlock problems
Posted: Sun Aug 25, 2013 1:06 pm
Ride: ford xh xr6
Hey mate I've had this problem all too much and I've only just repaired it. What you will need to do it get a smart lock bypass module from eBay. 125$ really straight forward to install and fixed it first go for me. But while you've got your ecu out I would advise to just check your ecu thoroughly while you have it out because when I had mine out I found it had a bit of corrosion in the pins. So just check that. Good luck :)
Posted: Sun Aug 25, 2013 1:25 pm
Ride: ef falcon futura
Power: 154 rwkw
why spend $125 on a smartlock bypass when you can get a Ti performance j3 for $120 with the smartlock disabled and you can get it tuned later for any mods you have
ef futura, pacemakers, 2.5inch catback, k&n panel filter and 3.45 lsd. extractors/cat, ticky head, custom cam grind, t5. now onto cosmetics.
It is currently Tue Jun 24, 2025 11:21 am All times are UTC + 11 hours
