kurt36 |
can any one help me out.
I got a xh ute just had motor out not long put it back in try to start it today wouldn't start for me unless I by pass the smart lock by putting a wire on the start motor then to positive on the battery and it went so have any one got a idea what it is please kurt36 is online now Report Post |
SWC |
Did you reconnect the Starter Motor solinoid wire?
kurt36 |
yes I did
SWC |
When you jump the starter, the car actually starts and runs?
What is the smartlock jewel doing? Is it flashing fast? Does it go out when you turn the key to reds? |
kurt36 |
it's start doesn't wont to kick over to fire
smartlock jewel is flashing fast. yes it.s dose go off |
SWC |
If the Jewel is flashing fast, then I suspect that you have a smartlock issue.
Reprogram the ignition to the BCM or give the BCM a smack. Is your fuel pump priming? |
kurt36 |
yes fuel pump is priming
I been smacking bcm no result there how do I reprogram ignition to bcm |
SWC |
Windows down, all accessories off, ie radio etc. Turn ignition to reds and wait 30 -60 mins (depending on car) when programmed, door locks should cycle twice. Turn ignition off and then try and start the car.
Is the ute an auto? |
kurt36 |
auto and on gas as well
SWC |
Did you plug the inhibitor switch back in?
kurt36 |
yes
kurt36 |
still no go I know I got a smart lock fitted to my ute but no remote for it
