XF GHIA king revving @ idle & accelerating by itself
Page 1 of 2 [ 27 posts ] Go to page 1, 2  Next
 Post subject: XF GHIA king revving @ idle & accelerating by itself
Posted: Mon May 22, 2006 9:21 pm
Ride: BA XR8 & 06 4x4 Bravo
Hey Guys,
My XF GHIA hasn't been driven for 3 months, yesterday I charged the battery up & kicked it in the guts, she started up fine & idle'd for a few minutes, I went inside to get my wallet so I could go put some gas in it & it king revved as hard as it could, I ran out & switched it off, had a quick look at the accelerator cable & it seemed ok so I started it up again & started to drive to the servo & as I was crawling over a speed hump it accelerated to 1/4 throttle by itself (the accelerator pedal moved) but backed off to idle when I pressed the brake & kept doing this.. I headed home real quick & put it into Park & idled it for a few seconds & it revved as hard as it could again. It was getting dark so I just left it.
I was going to lube the Accelerator Cable tonight & see if that helped but I've got a bad Cold today so didn't feel like going outside after work.
Any idea's of what else it could be?
'04 BA XR8
Winter White, 5 Speed Manual, Sports Leather, Premium Sound, 2 1/2" Cat Back Exh - no rear Mufflers, Lowered SL/SSL, 20's, Underdrives, BF Typhoon Rear Spoiler, GT Steering Wheel, etc.
Posted: Mon May 22, 2006 9:27 pm
does it have crusise control and could that be playing up?
Posted: Mon May 22, 2006 9:34 pm
I was thinking that, it does have Cruise but it's never worked.. But cruise wouldn't actually pull the Accelerator Cable would it? I've only used cruise in E Series onwards..
'04 BA XR8
Posted: Mon May 22, 2006 9:59 pm
e-series uses vacum to pull on the accelerator i know that
put cruise on and u can feel the pedal move...
Posted: Mon May 22, 2006 10:08 pm
Hmm, interesting.. That could explain why its accelerating by itself, something to do with the Cruise activating.. But doesn't really explain why its revving up @ idle..
'04 BA XR8
Posted: Mon May 22, 2006 10:22 pm
Ride: 1984 FD LTD
the cruise controll is worked by cable on the trottle Body, so yeah, you would feel the pedal being 'pulled' down as if you was pushing the pedal yourself..
thats the onlyt hing i can think of that would cause this problem for you...
hope that helps
Member Of "Team LWB"
FD: My Current Project
http://img.photobucket.com/albums/v146/ ... age029.jpg
ZL: A Work In Progress - that went to the tip!
http://img.photobucket.com/albums/v146/ ... maller.jpg
Posted: Mon May 22, 2006 10:30 pm
hope that helps
Sweet, when I get over this cold I'll either disconnect the Cruise Cable or take it for a drive & turn Cruise off & see if that helps.
'04 BA XR8
Posted: Mon May 22, 2006 10:40 pm
Gallery: 12 images
Ride: AU Falcon
cruise is not supposed to activate under 50kmh as far as I am aware but maybe having the battery slow discharge over the last few months has "confused it". I would try diconnecting the battery for a couple of minutes to reset the ecu etc and see if that works perhaps
98 AU Falcon Futura I6 ABS & Cruise stock (The Wifes car
99 AU Falcon Duel Fuel - Xcab
Posted: Mon May 22, 2006 10:42 pm
Ride: 1984 FD LTD
iv managed to get the cruise to work for me at 40km/hr in both my zl's, and mates zl's too...
group fault maybe?! lol...
anyhow
Posted: Mon May 22, 2006 11:01 pm
Yeah I know that, but I guess if somethings wrong with it, it might be able to activate..
The ECU would of reset when I took the Battery out to recharge, but I'll try resetting it again, can't hurt..
'04 BA XR8
Posted: Tue May 23, 2006 10:17 pm
Ride: 2009 FG XR6 turbo project
ahh accelerator sticking?
Posted: Tue May 23, 2006 10:34 pm
Ride: Triton ute BA Futura
He said it was idling dude - unless the boogyman punched the pedal i dont think so :P
Posted: Tue May 23, 2006 11:48 pm
Ride: Fordrunner 5.0 Turbo
Timing might be out causing a warm idle overrun condition? whenever mine was warm If I put it into neutral it would rev to around 3000rpm. ISC could also be sticking. Can't rmember if XF's had an ISC though.
Posted: Wed May 24, 2006 8:45 am
Nah I don't think it is, I've lubed the Accelerator Cable, if it was sticking it wouldn't cut out when I put my foot on the Brake, I'm convinced its the Cruise Control..
'04 BA XR8
Posted: Wed May 24, 2006 8:46 am
Don't think so, because it can idle fine for 2-3 minutes then it rev's it guts off..
'04 BA XR8
It is currently Thu May 22, 2025 9:02 pm All times are UTC + 11 hours
