flash69 |
driving an xf 4 speed which ive had for about a year. brother was driving it for a few months and replaced the clutch december last year and then i had to replace the clutch cable a few months ago after finding it was rusted and had completely seized. i have to replace the clutch again and was just wondering about the costs or options of changing to a different box. any ideas? im not really full of knowledge but am interested in fixing it up slowly
XFSteve |
Just a point if you have had a clutch cable seize. Check the firewall cable entry. I have known a number to crack around the slanted tube - about 20mm out from the weld. Eventually they fail, the whole lot breaks in and no clutch. Mine failed in 1995 about 1,000kms from home and made a tempory repair in a farmers shed. (took the photo today - so - was not so tempory after all)
Cheers XFSteve
_________________ Even a backfire from a Ford is a QUALITY BACKFIRE |
jaikai |
You go thru a lot of clutches...as above, check the spout for the cable, can be welded or ford still stock the XD-XE bolt in bracket. make sure the cable is clean and lubed too, when I put mine in, I CRC`d the guts out of it and flushed a bit of gunk out by sliding the cable and spraying more in, after I cleaned that off I used silicon spray...should be good for a few years.
Tranny wise, you prolly wanna keep the 4spd or go a T5, maybe C4 auto with a bit of grunt in front of it...BW40 will serve you well if you don`t abuse it JAIKAI |
The Dog |
All of the above!
_________________ You'll ride a black tornado across the western sky
Jim |
I did the swap to T5 from a 4 speed... completly different car.
flash69 |
how much would i roughly be looking at for a T5? ive had quite a few ppl tell me to do the swap n i want to myself so hopefully getting it done in the next couple of months
ceb^sk8 |
you can have my conversion minus peddal box for 400. box was reco 2 years ago. also comes with clutch only 3 months old if your intrested private msg me
