XE Drum to Disc Conversion (rear)
Page 1 of 1 [ 10 posts ]
 Post subject: XE Drum to Disc Conversion (rear)
Posted: Tue Jun 05, 2007 11:15 pm
Ride: XE S-Pack, ED Wagon
Hi all, I`ve just been given a complete XF rear end wih disc brakes. What I need to know is apart from the rotors, handbrake cable, Calipers and mounts and rear brake lines on the diff is there anything else I need? Or would it be easier to swap the whole diff?
TIA
Posted: Tue Jun 05, 2007 11:19 pm
Ride: 2.0 Turbo VW
Power: 142 rwkw
Also need to remove the proportioning valve from the master cylinder.
Posted: Tue Jun 05, 2007 11:31 pm
Gallery: 25 images
Ride: BA on gas. EL on gas. XF on gas.
ummm... put a disk rear end valve back in too... lol
change the whole diff it is easier than pulling axles and swapping brakes assuming they are both sedan diffs. Depending on how much you know about brakes, you may be better off getting another master cyl to suit disk rear.
Member Number 8804
Posted: Tue Jun 05, 2007 11:34 pm
I had the impression the master cylinders were all the same
Posted: Tue Jun 05, 2007 11:42 pm
Gallery: 25 images
Disk brakes need less pressure than drum brakes.
So rear lockup coud happen.
This valve controls your front to rear brake bias.
Member Number 8804
Posted: Tue Jun 05, 2007 11:54 pm
That was my preferred method. I can get the booster and master cylinder of the donor car also
Posted: Tue Jun 05, 2007 11:59 pm
Gallery: 25 images
As fer as I can remember the booster it is same for both.
Member Number 8804
Posted: Wed Jun 06, 2007 12:09 am
Done a quick check on PBRs website, lists the same part for both
:shock:
Brake M/Cyl 03/1982 - 08/1984 SEDAN, DISC/DISC, DISC/DRUM, 6 CYL, 8 CYL, 25.40 mm P10050
Posted: Tue Jun 26, 2007 5:27 pm
no. Disc brakes need more pressure than drum brakes.
Posted: Tue Jun 26, 2007 5:55 pm
Gallery: 25 images
Oops, you are correct.
Member Number 8804
cron
It is currently Sun May 25, 2025 12:50 pm All times are UTC + 11 hours
