XG change to XH surround
Page 1 of 1 [ 5 posts ]
 Post subject: XG change to XH surround
Posted: Sun Jul 15, 2007 9:05 pm
Ride: EB 5.0
I have an XG and am looking at putting an XH cluster surround to change it to the later switches along with the steering column for the hazard light switch. What I dont know is how or if the wiring is easy?....Does the XH have a harness I can unplug or am I looking at alot more work?
Anyway if anyone has done it I would be grateful for the advice.
EB 5.0lt 2.5" Exhaust Kings Super Lows blah blah
Posted: Sun Jul 15, 2007 10:34 pm
Ride: XG Pano
Im not sure if it will fit. I put a EB XR6 dash into my Xg so if ur lucky an Xh unit might fit. The Xg dash has 2 plugs in the centre and a small one in the bottom left hand corner. The dash is easy to get out you just need to unscrew the buttons and the surround and then theres 4 screws holding the cluster in. The whole thing can be out in 20 mins.
Hope this helps mate
93 Xg Panel Van: Globe Wheels, Lowered, 2.5 Inch Exhaust, Nice and clean with more to come
Posted: Mon Jul 16, 2007 12:01 am
Ride: 96 XH/97 EL
Nah, he's referring to the cluster surround. XH would look cleaner and better. XH is essentially EF wiring and XG is essentially EBII/ED wiring, so no direct plug and play.
Light switch: XH switch and knobs, EF/EL or XH plug and length of wiring to splice in.
Hazard lights: Use EA/EB/ED turn signal combo switch and upper column cover. Reroute dash hazard wiring to the column.
Demist switch: Use EF/EL item, plus plug and length of wiring to splice in.
I couldn't make out what the top left XG switch is . . . . :(
Posted: Thu Jul 26, 2007 9:52 pm
Ride: AUII ute e-gas
its the dash dimmer/ interior light switch. on xh its around the headlight switch so you'd need to extend/ reroute the wiring (be creative!)
incedentally if you're really up for a challenge, the entire xh dash will fit and it only takes about an hour to pull it out- xf to xh firewall (and therefore dash mounting points) are the same. There'd be a fair bit of wiring involved though
Posted: Thu Jul 26, 2007 11:47 pm
Ride: 96 XH/97 EL
You'll also need to run an ECU out of an XH or use an EL ECU to get all the cluster functions to work.
It is currently Wed May 21, 2025 5:48 pm All times are UTC + 11 hours
