XW rust
Page 1 of 1 [ 6 posts ]
 Post subject: XW rust
Posted: Sat Apr 18, 2009 5:45 pm
Ride: XT Fairmont XGXR6 BAXR6
Im looking for a XW - Y & was wanting to know where are the usual places these cars rust?
Brad
 Post subject: Re: XW rust
Posted: Sat Apr 18, 2009 6:56 pm
Gallery: 21 images
Ride: EL F100 CAPRI XR EF
Power: 234 rwkw
sill panels inside and out, doors, lower radiator support, floor pans under heater box, lower windscreen front and rear, lower rear quarters etc etc
Posted: Tue Apr 21, 2009 10:27 am
I had a look at a car last night.
It had rust in the main cross member at the passenger side footwells.
Can this cross member be repaired/replaced
Posted: Tue Apr 21, 2009 1:32 pm
Gallery: 21 images
Power: 234 rwkw
do u mean behind the passenger kick panel or sill panels maybe. anything can be fixed, just depends on what u want to spend.
any pics??
Posted: Fri Aug 21, 2009 1:55 am
Ride: XY 71
Dont worry mate. I recently bought an XY ute and it has all the comon problems with the rust. Nothing a mig and a sheet of black steel cant fix.
Posted: Sat Aug 22, 2009 1:13 pm
Gallery: 35 images
Ride: xy fairmont
i would say the one that is most likeley to sting you will be the heater box cant see it till you pull it out then you will see the damage the rest like the other guys said also a comon one that you can only see when the front guards are of is a part of the body behind the guard near where the door bolts on this can rust out to but easly repaired...also if it has all the crome triming can rust under that as well specialy check back window if its got crome around it...
If you have it under control then you dont have enough power..
There is no replacement for Displacment..
cron
It is currently Thu May 22, 2025 10:11 am All times are UTC + 11 hours
