EF 4ltr into carby XF ute
 Post subject: EF 4ltr into carby XF ute
Posted: Fri May 22, 2009 3:21 pm
Ride: AU fairmont ghia
am tryin to find out info on what needs to be installed into a XF carby ute to get a EF 4ltr running
is there a doc on it, search is down for the count
AU FAIRMONT GHIA: 5.0 Dealer ordered SVO mods ( seeking clarification ATM), tickford suspension.
 Post subject: Re: EF 4ltr into carby XF ute
Posted: Wed May 27, 2009 10:50 pm
Ride: XF ute
hi, yeah i just done mine,motor fits fine.you will need ea engine mounts and a xg sway bar ( still looking for one!).depending on what gearbox your going to use you may need modify the rear mount.i used the 4 sp auto but i had to unpick the rear crossmember and weld it into the the xf.i also used a ef wagon diff and tailshaft.bolts up perfect.there`s also radiator mods / header tank fitment.I don`t know about wiring as i have fitted the complete ef dash into the xf and used all ef harness.hope this helps.
Posted: Wed May 27, 2009 11:14 pm
have you got any pics you can post?
It is currently Sun Jun 22, 2025 6:11 am All times are UTC + 11 hours
