Xh longreach headlight adjustment
 Post subject: Xh longreach headlight adjustment
Posted: Fri Aug 07, 2009 8:15 pm
Ride: xh longreach
Well, i must be as thick as a brick, i have tried adjusting the headlights every which way, but i'm buggered if i can get them down far enough, anyone smarter than me? :oops:
 Post subject: Re: Xh longreach headlight adjustment
Posted: Fri Aug 07, 2009 8:36 pm
Is your car height standard or are you sagging in the rear?Is the thread stripped in the plastic adjusters and are the headlights actually fitted properly? and not to be silly or anything but you do know there is horizontal and vertical adjustment? :shock: and another thing is make sure the bulbs are installed properly.Cheers Kevman
Posted: Fri Aug 07, 2009 9:12 pm
Ride: xh longreach
the car is level, horizontal adj. is the screw located on top at the indicator end, both h/lights are new so stripped threads etc shouldn't be an issue...........i'm thinking about getting a h/light from the wreckers to see if the new lights are crook?........thanks for the quick reply
It is currently Sun Jun 22, 2025 11:55 am All times are UTC + 11 hours
