EF/L Cluster swap question
Page 1 of 1 [ 10 posts ]
 Post subject: EF/L Cluster swap question
Posted: Sun Aug 12, 2007 1:58 am
Ride: LS3 VF
just a quick one
if i install a high series BEM at the same time as the cluster, will i still need to add that diode/resister so the lcd's illuminate?
Posted: Sun Aug 12, 2007 10:20 am
Ride: 2007
No but you will need to change the headlamp switch and maybe the wiper stalk depending on your model - your profile suggest a futura so the stalk will be OK.
GQ XR6T ghia patrol.
,======o00o
//__|__|_,\_____\,___
|_/--\'_|'__|_/--\_[]IIII[]
_( o ) )_____( o ) )=o=) )__
Posted: Sun Aug 12, 2007 11:54 am
Ride: 2.0 Turbo VW
Power: 142 rwkw
as he said, however you add the resistor when adding a fairmont cluster to a gli/futura/xr.
remove when going low spec cluster to higher series dash loom.
Posted: Sun Aug 12, 2007 10:08 pm
Ride: 96 XH/97 EL
Any E series equivalent fairmont/ghia/LTD/Fairlane headlamp switch will suit for the replacement. Check for the green connector on the back of the switch body - gli/futura ones are a beige colour.
Also the wiring from the switch to the BEM needs to be modified, or changed.
Posted: Tue Sep 04, 2007 11:21 pm
Ride: LS3 VF
is a high series bem a straight swap to gain things such as fade in and out on interior lamps?
Posted: Tue Sep 04, 2007 11:37 pm
Ride: 94 Futura
Fade should happen with the Futura BEM
Posted: Tue Sep 04, 2007 11:39 pm
Ride: 2.0 Turbo VW
Power: 142 rwkw
High series requires wire mods and a fair bit of stuffing around,
A Mid series gives you Light fade, intermittent wipers, also time delay on window circuit. and is a direct plug in (ef-ef or el-el)
http://www.fordmods.com/forums/documents.php?doc=49
Posted: Wed Sep 05, 2007 12:57 am
Ride: LS3 VF
maybe it does, i havent actually checked, altho i do have intermitant wipers and also time delay on power windows.
Does any EL bem make the lights come on when key is turned off?
Posted: Thu Sep 13, 2007 10:15 pm
Ride: FGX G6ET
lights on when key is turned off...no E-series does this as far as I'm aware.
I upgraded my BEM in the XR6 with a high series one doing the climate control conversion. It was easier to just replace the dash loom with a high series one, then everything is just plug and play.
Posted: Fri Sep 14, 2007 9:43 pm
Ride: LS3 VF
not so important now, i just got a promotion with a company car
It is currently Tue Jun 24, 2025 11:42 pm All times are UTC + 11 hours
