Mystery Plug.
Page 1 of 1 [ 14 posts ]
 Post subject: Mystery Plug.
Posted: Sat Nov 03, 2007 8:55 pm
Oustide Australia
Can anyone please tell me what this plug is for ? car is an EB1 it comes off the headlight loom near the battery tray.
thanks ed_man........
God save Allan Moffat, God bless d**k-Johnson and thank Christ for Marcos Ambrose.........
 Post subject: Re: Mystery Plug.
Posted: Sat Nov 03, 2007 9:06 pm
Power: 144 rwkw
Wrong thread mate...try your luck in the 8 cylinder forum. (guessing it is a V8 due to the naming of your picture file.)
and which plug are you referring to? the black one in the foreground, or the white round one or the black rectangular looking one on the right?
I am guessing the white is for a light globe. Clueless about the other 2 sorry.
phong =P~
phongus = Post whore 2006
 Post subject: plug
Posted: Sat Nov 03, 2007 9:13 pm
Ride: EL XR8
Is your eb a fairmont? If not then that plug will be for either low water level sensor in the header tank or a outside temp sensor connector for climate control air con as found in the high series vehicles. As far as I can remember. Been 15 years since I worked at the local Ford dealership.
No matter where you go......... There you are
Posted: Sat Nov 03, 2007 9:44 pm
Oustide Australia
Hi
Yes the car is a Fairmont 6, and I was reffering to the black plug on the bumper bar. Yes the white plug is the indicator.
thanks.
Posted: Sat Nov 03, 2007 10:23 pm
Looks like the Climate Controll outside air temp sensor
Posted: Sun Nov 04, 2007 4:49 am
Don't know about the climate control stuff, because my EB is only a Gli, but I recently put in a Mid-Series cluster and I used that plug for the low water level sensor.
Posted: Sun Nov 04, 2007 12:50 pm
Normally the low coolant plug is located directly under the tank. This one was behind the headlight.
Posted: Sun Nov 04, 2007 1:13 pm
From that picture he looks like he has taken out his tank/lights and the plug was stretched over where they would be to rest on the bumper.
Posted: Sun Nov 04, 2007 1:14 pm
Nevermind, got confused.
Posted: Sun Nov 04, 2007 1:46 pm
hehehehehe *<grin>*
Posted: Sun Nov 04, 2007 3:18 pm
Ride: Boosted ED XR6, EBII Mont Wgn
Power: 252 rwkw
it's the auto self leveling motor/pump wiring plug.. all EBII and ED models have this fitted standard..
FordMods Member #1761
Posted: Sun Nov 04, 2007 4:03 pm
Ahhh Haaa,
forgot some of the earlier models had complete wiring harnesses. Before ford started skimping on wiring to save costs.
Posted: Sun Nov 04, 2007 6:26 pm
Oustide Australia
Yes I think you are correct, I looked at an ED Classic and it has the same plug just sitting there not connected to anything.
Posted: Thu Nov 29, 2007 9:54 pm
you will probably find that, that plug is for the self leveling suspension. the pump sits behind the gaurd next to the battery
It is currently Wed May 28, 2025 11:43 am All times are UTC + 11 hours
