el pedal box
Page 1 of 1 [ 14 posts ]
 Post subject: el pedal box
Posted: Fri Dec 05, 2008 3:20 pm
Ride: 05 XR6 Mk II Falcon Ute
any one got pics or tutoral on pulling a el pedal box out mine is cracked.... helplol
EL Futura 5 speed factory:PH47FL goneeeee :(
04 BA XR6 Mk II Sedan: XR67OY gonneee..
2010 250R ninja: gooneeee.
BF 2007 F6 typhoon:F6FOON gonnnee.
05 BA XR6 Mk II Ute: latest
Posted: Thu Dec 11, 2008 12:54 pm
Hi
This sounds harder than it is, but then again, it can be a real pain to do.
You need to undo the completed dash and pull it back as far as you can without unclipping the wiring.
Steps to remove Pedal Box.
1. Remove centre Console
2. Undo the five bolts holding the pedal box to the firewall. These are around where the steering column passes through to the engine bay.
3. Remove the split pin and bush holding the brake pedal to the brake master cylinder.
4. Remove the dash, there are four bolts, two on each side at the bottom corners of the dash, and two in the centre underneath the radio area.
5. Remove the plastic cowl piece covering the windscreen demister vents.
6. Undo the bolts along the leading edge of the dash pad. You may have to undo the earth bolt if the wiring does not have enough give.
7. Undo the two nuts holding the steering column to the pedal box. Lower the column as far as you can.
8. Unclip the bonnet catch handle from under the dash
9. Remove the left and the right kick panels.
10. Lift the whole dash up and pull back far enough to get a spanner to the three top pedal box bolts. Best to use a mate for this.
11. Pull the pedal box out.
To reassemble reverse the order.
If you look at the below picture of my EB Wagon with the dash pulled back you can see the pedal box and the three bolts you need to undo that are behind the dash.
I have undone the left hand wiring connectors as I was changing the pedal box and the heater box.
My best suggestion is to go and buy a Gregorys or similar workshop manual. The first thing any car owner should buy.
Good luck.
BenJ
{DESCRIPTION} - Current Ride
{DESCRIPTION} - Previous Ride
Posted: Thu Dec 11, 2008 5:35 pm
thats ridiculas i pulled this out so far...... look at pic, do i need to pull the speedo and that out like ive already done or just the actuall dash its self?????
You do not have the required permissions to view the files attached to this post.
Posted: Thu Dec 11, 2008 7:49 pm
You don't need to dissassemble the parts you have.
The WHOLE DASH needs to be undone and moved back.
Where in Sydney are you Clampy?
Call me on 0401 851 347 if you need more help.
BenJ
Posted: Thu Dec 11, 2008 8:10 pm
Power: 144 rwkw
Clampy...there are certain bolts that need to be removed to pull the WHOLE dash away from the firewall.
There are a few bolts running along the bottom of the windscreen under the plastic cover that cover the factory tweeters. Remove that plastic mould/cover and then remove the main bolts (I believe they are all 10mm bolts)...make sure you remove the earth bolt too so not to snap the wires, it is painted green. It is also wise to unclip some of the wires just in case they get caught and snap.
There are also 4 bolts located underneath. 2 are located on either side behind the kick panels. So remove the kick panels and you should see 10mm bolts, remove those.
There are 2 in the middle console, they are a bit of a prick to get to because they are sort of hidden, but still accessible with a socket on a long extension. Since you already removed the head unit and centre console, you should be able to get to them easily. They are locate on either side underneath the steel frame/bracket that holds the head unit. Best way to spot them is to plant your cheek where the gear boot is and have a squizz underneath the steel frame. Remove those 2 bolts and you would have completed removing all of the main bolts and you can remove the dash as a whole.
Another thing, before your remove the dash, remove the bolts that hold the pedal box to the firewall...once those are removed, remove the bolts holding the steering column up and lower the steering column.
Once all the bolts are removed, get someone to help you and heave the heavy dash upwards to unhook it and then back away from the firewall. Get your helper or yourself and unclip any wiring if you can't get it out far enough to reach the top 3 final bolts. I recommend unclipping the wiring just to make sure...making sure you know what clips to what.
hope that helps...
phong =P~
phongus = Post whore 2006
Posted: Fri Dec 12, 2008 11:08 pm
thanx that makes it easier ill give it a go on sunday put every thing back then do the bolts stated thanx for all ya help....
Posted: Sun Dec 14, 2008 12:13 pm
where are the bolts for the middle console i got a few out but is there some hidden in the back of it near the a/c vents cause i cant get it off
Posted: Sun Dec 14, 2008 12:21 pm
the bolts are close to the floor to the left and right of the Console A/C vent inlet.
BenJ
Posted: Sun Dec 14, 2008 12:50 pm
Gallery: 25 images
Ride: 1999 AU futura
I have removed and fitted a couple of pedal boxes to the e series falcons.I havent removed the dash to do one.All i do is remove the steering column.The last one i did was in a manual AU ute.
COMING SOON,XD WITH A TURBO...CLEVO STYLE
Posted: Sun Dec 14, 2008 1:22 pm
how many bolts to do the steering column...... do u have to remove any thing to get to the steering column bolts
Posted: Sun Dec 14, 2008 1:58 pm
Gallery: 25 images
Make sure you disconnect the battery before you start.
Remove the lower cover and upper cover of the steering column.
Disconnect the harness on the steering column.
Remove the key from the ignition and lock the steering column by turning the wheel.This will prevent having the colum out a turn to the steering rack.
Loosen and remove the bolt at the steering shaft inside the car where it is multisplined you can mark this to make sure it all goes back in the same spot.
Then you can loosen the 2 bolt up near the bottom of the instrument cluster i think they are 13mm nuts.
Now you can remove the steering column.
After this it is alittle tricky to get to the upper bolts of the pedal box but it is doable.On one model i dont remember you have to trim or bend alittle material back.
The tools i used were a combination of 1/4 drive and 3/8 set with the use of both sized universal joints and paitence but once you do one the next is easier.
Also there was one i did where i removed the speedo cluster i have no idea why,but just thought i'd mention it.
This way is alittle trickier but i was taught this way by my boss who has worked on fords for more than 25yrs.
See how you go.
Posted: Sun Dec 14, 2008 2:14 pm
yeah well i already removed the dash and i didnt disconnect the battery now its making a ticking noise from the blue box near the steerin column and the doors wont lock whats wrong there
Posted: Sun Dec 14, 2008 4:31 pm
well it was an asle but the pedal box is finnallly out what a mission not looking forward to putting it all together..... here is some pics of the crack pretty bad but i gunna get the boiler maker to fix it for me at work tomoz and put it all back together then in for a new clutch before xmas..... thanx for all ya help every one.....
Posted: Mon Dec 15, 2008 4:34 pm
well shes all welded up and gunna put it back together after work tomoz..... hopefully new clutch by friday
It is currently Tue Jun 24, 2025 2:25 am All times are UTC + 11 hours
