I wonder if these will fit E-Series.
 Post subject: I wonder if these will fit E-Series.
Posted: Wed Jan 05, 2011 2:51 pm
Ride: Peacock EB Falcon
http://www.wilwood.com/Calipers/Caliper ... =120-10939
They look like they'll fit the discs but I'm just wondering if the E-Series hubs have the same mount.
 Post subject: Re: I wonder if these will fit E-Series.
Posted: Wed Jan 05, 2011 7:54 pm
Ride: FG MkII Xr6t Ute
Do you mean as a bolt in replacement? (as that link indicates for certain vehicles?)
If so, no. I'm sure you could do it, but by the time you did would probably be better off with one of the RBS/RBM/ebay ones. These all address the main issue that the rotors are neither thick enough or of big enough diameter.
Cramping in the hand from having it on your Wang for an excessive period of time is a definate con.
Seriously do people google "f**k up modifications for Fords owned by Jews" and get linked straight to this site nowadays?
AU,factory fitted tickford kit/IRS, t5,Sports ryder/KYB: gone.
Posted: Fri Jan 07, 2011 6:18 pm
Well, I did some measurements today and the bolt spacing is 15cm, from the back of the slides to the front of the caliper is 7cm and from the back of the slides to the base of the bolt head is 5cm.
Better caliper's alone will be a brake upgrade from the cast iron travesty that ford lumped us with, so yeah... milling off the slides to mount a decent caliper is an option.
Posted: Fri Feb 18, 2011 10:35 pm
Hrm, territory rear brake calipers... anyone got any measurements?
It is currently Thu Jul 10, 2025 6:41 am All times are UTC + 11 hours
