XD 351 Ute...ways to lower revs?
Page 1 of 1 [ 11 posts ]
 Post subject: XD 351 Ute...ways to lower revs?
Posted: Mon Apr 25, 2011 9:05 pm
Ride: 5lt Turbo NC, TE V6 Gemini
A mate has a mild 351 in a XD ute with a single rail and 3.7 diff gears, and is looking for ways to make it a little more highway friendly. At the same time, he is considering going auto, but has no idea of what auto he wishes to put in it. Any suggestions of ways to make it a bit more rev friendly without losing the snappiness of the 3.7 gears?
 Post subject: Re: XD 351 Ute...ways to lower revs?
Posted: Mon Apr 25, 2011 9:17 pm
Gallery: 17 images
Ride: 5.0lt NF /351 ZD Fairlane
Well without seeming to obvious, 5 speed conversion, or I'm pretty sure there is an overdrive that can be fitted to a C4, but not sure where to get one! It is a shame the BTR latemodel boxes aren't viable as they do drop revs quite nicely.
NF Fairlane with 5.0 and 5 speed goodness!
XE Fairmont Ghia
Posted: Mon Apr 25, 2011 9:22 pm
Gallery: 17 images
When I went to to the Koala Pk show a few yrs ago my mate in his 351C w/ 3.9's followed me up the freeway, not aware I sat on 110 (at about 2,200) while he was struggling behind me sitting on around 4,000 revs! But with the ZD (3.5's and 14" rims) it sat on 3,500 at 110 and I thought it was OK, but these days it seems too high. :wink:
XE Fairmont Ghia
Posted: Tue Apr 26, 2011 2:27 pm
Out of curiosity, why isnt a BTR a viable option?
Posted: Tue Apr 26, 2011 2:33 pm
Power: 139 rwkw
Too much work to make it run correctly.
It needs the electronic controller to run which needs the inputs from the ECU. I do believe someone made a stand alone unit but to got to the expense and drama (bellhousing is different etc etc) to end up with a box with s**t ratios and isnt all that strong until they are built just isnt worth the effort or financial outlay.
An AOD fromt he states is a transmission that will bolt in where a C4 was but has the overdrive 4th gear.
Not a cheap exercise but very much worthwhile.
Posted: Tue Apr 26, 2011 6:20 pm
Gallery: 17 images
Thanks Matt - couldn't have said it better myself! :D
XE Fairmont Ghia
Posted: Wed Apr 27, 2011 12:26 am
Thanks heaps guys, i think he's deicded to sell a car and buy a T56 to put behind it lol
Posted: Wed Apr 27, 2011 12:32 am
Gallery: 17 images
Noice! :D
XE Fairmont Ghia
Posted: Wed Apr 27, 2011 12:57 am
Gallery: 25 images
For any highway duties it would need to be a 4spd auto, or a 5spd manual, as you will need the overdrive gear to drop the revs down on the highway.
My torana used to cruise a bit over 3000 on the highway with a 3spd manual, with a 1:1 top gear, 3.36 diff gears & stock 13inch tyres. I dropped the rev's a fair bit when I fit some 14's with 205/70 R14 rubber on the back rims. Sitting on 8 inch wide rims, it was a nice big increase in rolling diameter, dropping my highway rev's a fair bit. I don't actually remember how much, because my tacho was broken by then, but you can use some tyre calculators out there on the internet to to work out what you currently have, and then punch in a larger rolling diameter tyre size to see what it will drop your rpm's by.
Might be an idea, bigger rear rubber? Will give it an old school look with a slight rake forwards too.
ToranaGuy
Posted: Thu Apr 28, 2011 11:38 am
EFI Guru
Gallery: 28 images
Actually, I've done a BTR conversion on a 351C with a carb years ago. Works well and you don't strictly need inputs from the EEC.
Certainly the best option though is an AODE/4R70W and a controller like the optishift from Baumann engineering.
It is currently Mon May 19, 2025 12:40 am All times are UTC + 11 hours
