Lowered ED now causing vibrations?
Page 1 of 1 [ 8 posts ]
 Post subject: Lowered ED now causing vibrations?
Posted: Tue May 10, 2011 7:27 pm
Ride: 1994 falcon
Hey guys i recently lowered my ED with shortened rear shocks and ultra lows.
now i get a vibration at 30kms, goes away and then a vibration between 50-60km, unless im going full acceleration, i get no vibration at all.
it also vibrates around 50km when i am de-accelerating.
has anyone had this trouble before? it doesnt feel like its coming from one perticular point, but im hinting towards the diff?
any help is appreciated
RIP XS7261
 Post subject: Re: Lowered ED now causing vibrations?
Posted: Tue May 10, 2011 7:28 pm
Power: 139 rwkw
The pinion angle is screwed.
Posted: Tue May 10, 2011 7:29 pm
Power: 144 rwkw
Tailshaft uni joints could be causing it.
phongus = Post whore 2006
Posted: Tue May 10, 2011 9:07 pm
Ride: 1994 falcon
hmmm thought it could have been the pinion angle, any way i can fix it? anyone else had the same problem?
RIP XS7261
Posted: Fri May 13, 2011 12:25 pm
Ride: 92 EB Fairmont
personally i think ultra's are to low for the e-series ( Street use any way) ,its bad enough with superlows .the lower you drop it the more your altering the angle of your tail shaft to the diff ,its most likely hitting your floor pan ,easy fix raise it up ,im using pedders superlows allround my EB and it sits nice no noise or vibrations
Posted: Fri May 13, 2011 2:41 pm
Ride: Peacock EB Falcon
Posted: Mon May 30, 2011 3:08 pm
Ride: 1994 falcon
o cheers for that knowsfords!
got quoted $530nzd for them, seems a bit steep? anyone form newzealand found anywhere cheaper to get them?
cheers
RIP XS7261
Posted: Tue May 31, 2011 2:45 pm
Ride: 1994 falcon
or by the looks of it they look the same as standard ones, just with a nut which im guessing is threaded into the rod to give it udjustability? if u get what i mean... is it possible to just modify the standard ones?
RIP XS7261
It is currently Sun May 18, 2025 11:40 am All times are UTC + 11 hours
