ef inner lower control arm bushes
 Post subject: ef inner lower control arm bushes
Posted: Fri Jun 17, 2011 11:05 am
Ride: ef 2 fairmont ghia
hey guys,
i just wanted to know, im changing my bushes in the front end of my car.. i got the inner control arm bush off but when i put the new ones in i realized there's no metal washer on the end on them?
does the inner lower control arm bushes need to have a washer on each end so its not in contact with the k frame, or is it just directly on it?
 Post subject: Re: ef inner lower control arm bushes
Posted: Fri Jun 17, 2011 11:12 am
Ride: Kia Rio - 1.4L Auto
Power: 238 rwkw
If you're replacing them with Nolethane or Super Pro, then no, there is no washer on either end.
Just make sure you lube up the face of the bush where it contacts the k-frame to make sure it doesn't squeak or die early.
Posted: Fri Jun 17, 2011 11:14 am
great, thanks for that mate. Yes its being replaced with a poly urethane bushes so there all lubed up.
It is currently Mon May 19, 2025 2:08 am All times are UTC + 11 hours
