BA Calipers on AU3
Page 1 of 1 [ 12 posts ]
 Post subject: BA Calipers on AU3
Posted: Mon Jun 27, 2011 9:36 pm
Ride: AU III XR6 HP
Do BA rear calipers bolt up to an AU. Iv been told yes Iv been told No. Can anyone give me a definitive answer. Looking to upgrade my rear brakes as they are s**t and iv had the fronts rebuilt already. Cost WAY too much. Was better off buying second hand ones. Thanks guys
 Post subject: Re: BA Calipers on AU3
Posted: Mon Jun 27, 2011 11:26 pm
Ride: AU III XR6 HP
anyone? Yes? No?
Posted: Tue Jun 28, 2011 12:47 am
Gallery: 25 images
Your AU live axle or IRS?
ToranaGuy
Posted: Tue Jun 28, 2011 8:01 am
If you have a live rear axle you CAN fit BA rear wagon/ute brakes but you will either need to change the backing plate or put a washer between the calipers where they bolt on, the chnage of backing plate is much better.
I cant answer for the IRS but I guess you could use the washer method to space the caliper.
I have an AU I XR6 with live axle and will be changing mine soon, I have the backing plates from a BA wagon to do the job.
Posted: Tue Jun 28, 2011 1:18 pm
Ride: AU III XR6 HP
thanks mate. Any idea how much the backing plates are worth? Can i get a brand new set from ford ?
Posted: Tue Jun 28, 2011 1:19 pm
Ride: AU III XR6 HP
forget to mention too running the live axle
Posted: Tue Jun 28, 2011 1:24 pm
Ride: EL XR6
Would this work on a el? As they have a similar diff to Au 1 .
Sorry to hi jack
El XR6 Turbo
Dark Agents,Sunroof, bilstein shocks, 6000k HIDS, 329 mm slotted rotors, twin pot calipers , Climate Control, GarrettT04 turbo,log manifold, crow turbo cam, microtech lt10c, 42lb injectors , 044, surge tank , T56 , rebuilt bottom end , alloy plenum .
Aiming for 300 rwkw
Posted: Tue Jun 28, 2011 2:47 pm
The backing plates are available NEW from Ford. L/H BA 2212 C $128.40, R/H BA 2211 C $130.44
More than likely you could pick up a set from BA wagon or ute for a lot less. :)
Posted: Tue Jun 28, 2011 2:48 pm
Sorry to hi jack
I couldn't see why you couldn't get the calipers to fit your backing plate but you may have to space them out with a washer OR, chnage the whole backing plates but that I can't guarantee.
Posted: Tue Jun 28, 2011 7:42 pm
Ride: AUII XR6 Uterus
can you post a parts list drawing showing the location of said plate George ? just to be clear.
only if it's not a hassle of course.
I've been told terry brakes will fit on my live axle AUII ute.
Posted: Wed Jun 29, 2011 8:14 am
You would have to change the backing plate and get a High Series brake Ute or wagon one and also the dust shield. There is a little difference between the Territory Caliper and the High Series Ute/Wagon type but I am guessing you could use the Territory one?
The Backing plates are R/H BAFC2 2C220 A $217.10, L/H BAFC2 2C221 A $217.10, Dust Shield R/H BAFC 2A481 A $31.85, L/H BAFC 2T001 A $31.85.
Those prices are full retail and I am sure that you could get these from a Wreckers like FTG?
Hope that this helps :)
Posted: Wed Jun 29, 2011 7:49 pm
A wealth of information as always, thanks George.
It is currently Tue May 20, 2025 6:00 am All times are UTC + 11 hours
