Timmy97EL |
iv'e noticed lately that the tranny in my el has started to whine, i can hear it over the exhaust which must mean its fairly loud! it gets louder as the revs go up then goes away as it changes gears.
could it just be in need of a service? would low oil cause this noise? thanx
_________________ "In the absence of orders find something and kill it." |
Timmy97EL |
Anyone??
nannas_ed |
im not tos ure but i would like to know as mine is doing the same thing. how many k's has yours done timmy. it may be that it is just starting to show its age
Disco Frank |
my tranyy whines all the time but it sounds normal and has always been there
_________________ RIP SCOTT |
smee |
Mine I noticed the other day in O/D - the 1st time I've have the Music turned down!
offyaguts |
My car has the same whine - apparently its bits of brass from the radiator coil or something that flows through the system and gets trapped in the back a*** of the transmission, causing the whine. The only way to get rid of it is to pull the transmission down and put in a new gear set which pretty much isn't worth it, might aswell get a secondhand or a reco'd box. I haven't bothered doing anything with mine but it did get a tranmission service and it didn't do anything.
Instead of getting mine fixed, i'm just waiting for a V8 T5 to come along so I can do the conversion. |
NC 5ltr |
{USERNAME} wrote: My car has the same whine - apparently its bits of brass from the radiator coil or something that flows through the system and gets trapped in the back a*** of the transmission, causing the whine. The only way to get rid of it is to pull the transmission down and put in a new gear set which pretty much isn't worth it, might aswell get a secondhand or a reco'd box. I haven't bothered doing anything with mine but it did get a tranmission service and it didn't do anything.
Instead of getting mine fixed, i'm just waiting for a V8 T5 to come along so I can do the conversion. actually when i got my rtanny serviced the bloke there showed me thwose brass shavings that came from radiator,he said that he could bypass the gearbox somehow ,when i get it done ill tell ya's
_________________ "Looking at cleavage is like looking at the sun. You don't stare at it. It's too risky. You get a sense of it and then you look away."
offyaguts |
Probably wont get the brass out that is already in there though I wouldn't imagine. Be good to hear another opinion, as the guy I spoke to about it was probably biased on me getting a new tranny so he will repe the benefits
Users browsing this forum: No registered users and 35 guests |
