kiwief |
Hey guys, does anybody know the ID and OD of a t5 pilot/spigot bearing. E series I6. Or any information I could give to the guys at the bearing shop to make sure I get the right one. Genuine Ford is $61 + gst, My thrash engine was only twice as much as that so a 10 dollar cheapy will do the trick!
EDIT: RIPCO has one for an EA, will this fit an EF crank? Its an earlier e series box, but if anything I would assume the OD would be different? Thanks guys |
Papa Smurf |
These bearings have been used for years. The Genuine one from Ford is $27.60 retail. I am not sure of the freight to NZ but I can't see it being that much??
evxr6 |
I got one from Repco. It was about AU$6.00. It is a 6003-2RS. It's ID is about 27mm OD 35mm Approx.
Thanks, Evan. |
BEAR80 |
Age: 45 Posts: 683 Joined: 4th Mar 2010 Ride: BF Fairmont Ghia & TS Magna Location: central coast |
if the bearing is a 6003-2RS then it's size is 17mm x 35mm x 10mm according to this {DESCRIPTION}.....
evxr6 |
{USERNAME} wrote: if the bearing is a 6003-2RS then it's size is 17mm x 35mm x 10mm according to this {DESCRIPTION}..... Sorry, I'll stand corrected. |
BEAR80 |
{USERNAME} wrote: {USERNAME} wrote: if the bearing is a 6003-2RS then it's size is 17mm x 35mm x 10mm according to this {DESCRIPTION}..... Sorry, I'll stand corrected. no need to be sorry, at least you put a part number up and at least now the op knows what to look for..... |
kiwief |
Thanks Papa Smurf, I would have taken you up on the offer if this was a decent motor, but I'm tired of seeing the mont in the garage so I picked up a $150 thrash motor.
Thanks to everyone else as well, that was exactly what I was looking for. I got the one from repco that was for an EA, but the dimensions are exactly the same and it looks the same. Part number is 6003LLU/2AS. In the end that motor already had one in it, but it looks a lot different, has teeth that line up with the input shaft? I have nothing to go on, because it turns out the garage who put my t5 in "forgot" to put one in. Thanks a lot for all the input. |
Users browsing this forum: No registered users and 36 guests |
