creeture3 |
All hail fellow petrolheads
![]() I wish to replace the rear control arm bushes, but first I must remove the originals. According to my manuel, I need a "bush removal tool" #9281A111 and #9281CI13 PLUS #9281C/12 ![]() I reckon there has to be an easier (cheaper) way....... Can one of the good people out there offer any suggestions. ( I do own a good press) I will probably be replacing the bushes with Nolathane or equivalent, which I know come in two parts and can be fitted easily. I await replies with bated breath............. ![]() |
mitchell g |
could the correct diameter round bar or socket be useable?
cjh |
{USERNAME} wrote: All hail fellow petrolheads ![]() I wish to replace the rear control arm bushes, but first I must remove the originals. According to my manuel, I need a "bush removal tool" #9281A111 and #9281CI13 PLUS #9281C/12 ![]() I reckon there has to be an easier (cheaper) way....... Can one of the good people out there offer any suggestions. ( I do own a good press) I will probably be replacing the bushes with Nolathane or equivalent, which I know come in two parts and can be fitted easily. I await replies with bated breath............. ![]() You can remove your arms and take them to a Pedders dealer, and they should be able to exchange them, if not, R&R yours.......or, if you want better ones, a Fulcrum Suspension dealer.
bry40l |
Have seen them burnt out with an oxy.
_________________ BF XR6 |
Johnson stroker |
Though you may have ment this kind of bush removal tool.
Sorry. Not helpful ![]()
creeture3 |
Quote: You can remove your arms and take them to a Pedders dealer, Have you seen how much they charge ![]() Quote: Though you may have ment this kind of bush removal tool. Sorry. Not helpful ![]() ![]() ![]() ![]() |
ef_falcon_95 |
Pedders want $22 a bush , when you have 11 it becomes expensive , you can do then with a press but you'll only press out the rubber and not the out tube which is really thin , you'll have to use oxy and a hammer and cheisel , or a dye grinder .
