BF IRS With 3.45 Diff Into BA
 Post subject: BF IRS With 3.45 Diff Into BA
Posted: Tue Jun 12, 2012 7:43 pm
Ride: Falcon EF
hey,
On the weekend i put a irs from a bf with a 3.45 diff into my falcon ba xt, everthing lined up perfectly and bolted in fine, put the tailshaft weights back in the right place, took her for a spin and there was a terrible vibration from roughly 60kms onward.. is there anyway the xr6s take a different tailshaft to the standard xt models, a seen a line on the diff there was one on my old one too, i was thinking that is the diff lined up to the tailshaft in a specific way?
im outta ideas.. if anyone could help would be appreciated...
Thanks
 Post subject: Re: BF IRS With 3.45 Diff Into BA
Posted: Thu Jun 14, 2012 4:49 pm
Ride: LS3 VF
did you align the subframe using aligning pins? if the subframe is out of alignment it will cause vibrations as well
Posted: Thu Jun 14, 2012 5:04 pm
Gallery: 12 images
Ride: BA XT V8
i would say so.
maybe try undoing the tailshaft and spinning it a bit and line up a different set of bolt to see if that makes it better / worse?.. then it will just be a case of elimination till you get to the right spot.
BA XT V8. Ice Mint. 18" Speedys. XR6T LSD. Full Pacemaker twin 2 1/2inch Stainless Steel system. Custom CAI. Black XR interior with white trimming. Powerbond underdrive kit 25%.
13.65@102mph. 2800 hi-Stall.
230RWKW@5250 rpm. 625NM.
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 83 guests
It is currently Thu Jul 10, 2025 4:51 pm All times are UTC + 11 hours
