Gav_21 |
Hi all after searching for the last 9 or so months for a manual conversion for my EL xr8 with no luck, I've decided to use a I6 box with a modified input shaft. The trouble im having now is finding a place in SA that will extend the input shaft lol was hoping a few members on here would know Of any companies that will do it? Prefer in SA but If I can't find anyone here to do it i will look at getting it done interstate. Cheers
TROYMAN |
try dellow automotive
http://www.dellowconversions.com.au/contactus.html |
fiend |
Chop and weld and input shaft? Sounds nasty...
You could get someone to machine an entire shaft... Like Troyman is saying?! Or, something like this...
Commonwhore http://www.ebay.com.au/itm/t5-v8-gearbo ... 2a1ef1a7dc http://www.ebay.com.au/itm/Ford-Au-T5-/ ... 3f18cd3fe5 http://www.ebay.com.au/itm/Ford-Falcon- ... 35aad2a5be http://www.ebay.com.au/itm/PRO-SERIES-B ... 19d18dea93 (Dreaming) EDIT ---- My old mate up the road uses Toyota gearboxes in his 302 powered Toyota Land Cruiser. To do this he got a plate made that bolts to block and has the bolt up pattern for the Toyota bellhousing. Much stronger than the T5 anyway?! |
ef_falcon_95 |
Maybe dellow or malwood have a custom bell housing which can let the input shaft poke out further ??
Off topic but someone was saying u can put a lancruiser gear box in a falcon. Doubt it would work as the gear box has a transfer case and is 4wd lol
fiend |
Yes, the LandCruiser bolts up if you have a plate made to convert the Toyota bellhousing to the 302. Made from 10mm steel in the version I have seen. Not sure if you need to pack anything out for clearances, but looks like simplicity itself.
Delete transfer case and run the landcruiser diff while you're at it! |
ef_falcon_95 |
Would it would in a I6 with standard diff ? How much torque / ft pounds can they handle . I'm guessing more than a t5 ??
Krytox |
go to CRS and get a BH107B bell housing.
for $500 plus some minor items, you can throw in all the 6cyl T5's you like. You MAY need a yolk or auto tailshaft, or it may mate up without any problems. Im sure they can tell you.
Users browsing this forum: Facebook [Bot] and 12 guests |
