What hydraulic press to buy?
 Post subject: What hydraulic press to buy?
Posted: Mon Jul 02, 2012 5:25 pm
Ride: EF Wagon
I'm considering buying a hydraulic press to replace the ball joints on my EF Wagon in the next few months to save some time running off to a mechanic and then picking them up again. I'd also like a press that I could do larger jobs with in the future like rear axle bearings.
I'd appreciate advice on what to buy - 12 Ton, 20 Ton, other? Any brands too look for or avoid?
96 EF Wagon, PRINS VSI LPG, Wade 1636, 4480's, Redback zorst, Metalcat, 3 angle valve job, .5mm overbore, hypertec pistons, shaved head (because the head was banana shaped when I brought it), Tickford 16" alloys, KYB shocks, 30mm sway bar, 1 1/2 degrees negative camber, tow bar, roof racks.
 Post subject: Re: What hydraulic press to buy?
Posted: Mon Jul 02, 2012 7:14 pm
Ride: EL XR6
i wouldnt worry about a press, i brought one to to ball joints but it was s**t, kept flexing and shooting the packers out. plus you need a tool/jig to get the ball joints out, cost me $40 to get ball joints pressed out and in. so much easier.
El XR6 Turbo
Dark Agents,Sunroof, bilstein shocks, 6000k HIDS, 329 mm slotted rotors, twin pot calipers , Climate Control, GarrettT04 turbo,log manifold, crow turbo cam, microtech lt10c, 42lb injectors , 044, surge tank , T56 , rebuilt bottom end , alloy plenum .
Aiming for 300 rwkw
Posted: Mon Jul 02, 2012 9:27 pm
Ride: AUII XR6 Uterus
agreed, the problem is the tooling.
Posted: Thu Jul 12, 2012 7:14 pm
Gallery: 25 images
If you want a press to do rear axel bearings & other large items you will need to go for a press that is rather tall, 12t will be enough force to do the job, but the press needs to be able to fit the axel into it.
In regards to the ball joints, tooling makes all the difference, there's a special tool for making life easy in regards to doing the ford ball joints, if your going to do a few sets it might be worth buying it, if only one or two sets it's just not worth it.
ToranaGuy
Users browsing this forum: No registered users and 82 guests
It is currently Fri Jul 11, 2025 12:19 am All times are UTC + 11 hours
