Vic |
Reposting this from the V8 category.
I need another intermediate shaft for my EL and of course Ford no longer produce these parts. I believe I have tried Bursons etc in the past but no joy. Does anyone know if aftermarket intermediate shafts are available and if so, where from?
Johnson stroker |
Vic, As far as I am aware, nobody is doing aftermarket or refurbished intermediate shafts. Best option is finding one out of a wreck and hope for the best. then become a tightass and start stockpiling the f**k.
ToranaGuy |
Intermediate shaft? Do you mean tail shaft? You can get them reconditioned.
Cheers ToranaGuy
Johnson stroker |
Nah, intermediate shaft from steering column to the rack.
They are getting rare.
cjh |
Ford stopped doing them about 5 years ago now.
ToranaGuy |
{USERNAME} wrote: Nah, intermediate shaft from steering column to the rack. They are getting rare. Ah, steering intermediate shaft. Couldn't one be reconditioned with new pins & bushes if you were desperate? I know I've thrown a few good ones out when car's go to scrap, so I should start keeping them shouldn't I? Cheers ToranaGuy
Vic |
This is the second one I've worn out and it lasted only a few years from the heat of the headers and I got it from Ford just before they stopped selling e-series parts.
I'm still hopeful that someone is doing an aftermarket version.
snap0964 |
gearbox-suspension-brake-driveline-f4/el-falcon-steering-universal-joint-t100861.html
fordmods-technical-documents-diy-f38/ask-papa-smurf-about-genuine-ford-parts-t82779-1875.html http://stores.ebay.com.au/Textile-Techn ... 4340.l2563
Vic |
I had the shaft welded.
Sorted. ![]()
snap0964 |
So what was actually welded ??
SWC |
I take it that there was play in the pin where the bottom Uni Joint connects?
Vic |
The uni joint itself was in fact fine, no wear in its movement.
The smaller pin underneath it ( in the attachment below ) was worn and received a couple of welds. This saved me over $200 in finding another new intermediate shaft. ~ Incidentally, yes, the V8 shaft was about an inch shorter than the I6 shaft.
Users browsing this forum: Google Adsense [Bot] and 16 guests |
