kensback82 |
Will a brake booster from a DL LTD fit my series 1 au ltd? i know the masters are different but got told the booster is the same, just want to confirm it before i go pulling it all apart.
_________________ "NEAR ENOUGH IS GOOD ENOUGH" |
Matt_jew |
Is your series 1 AU booster steel or plastic.
DL will be plastic.
kensback82 |
the au is plastic also, so i guess they are the same then?? hopefully.
Esteven8 |
Yes. AU1 boosters are interchangeable with the N.D.E.F./L ones. They changed to the metal ones in the AU2s.
Shen Long |
Age: 50 Posts: 391 Joined: 22nd Aug 2008 Ride: 2002 AUII Fairlane Sportsman V8 Location: Roxby Downs |
it will fit & work bud, but i would suggest & recommend the AU2 type booster & master cylinder.
Apparently its got better internals or something (bore is bigger) & its a better setup (from what i have heard). |
