Lower Trailing arms bushes. Help, I'm stuck!
Page 1 of 1 [ 13 posts ]
 Post subject: Lower Trailing arms bushes. Help, I'm stuck!
Posted: Sat Oct 20, 2012 9:47 pm
Ride: BAII Futura
Being a tight a$$, i bought a set of bushes to retrofit my lower rear trailing arm instead of shifting an extra $200 to get the complete assembly.
I just figured out that the shell from the old bushes needs to go.
Can it be easily pressed out?
I noticed the bushing manufacturer advises to remove only one lower arm at a time.
What happens when removing both at once?
Thanks for your assistance
 Post subject: Re: Lower Trailing arms bushes. Help, I'm stuck!
Posted: Sat Oct 20, 2012 9:55 pm
this will be an interesting read im going to want to know what people say
Posted: Sat Oct 20, 2012 9:59 pm
Ride: ef falcon futura
Power: 154 rwkw
mate i just done that to mine. the wide bit your measuring is the outer shell to the old bush, you need to get that out (prick of a job) then press the new ones in.
ef futura, pacemakers, 2.5inch catback, k&n panel filter and 3.45 lsd. extractors/cat, ticky head, custom cam grind, t5. now onto cosmetics.
Posted: Sat Oct 20, 2012 10:01 pm
Power: 154 rwkw
mine wouldnt press out with a 20 ton press so i used a die grinder to cut two lines through the old bush then easily used a hammer and chisel to knock it out
Posted: Sat Oct 20, 2012 10:04 pm
nice idea , and i assume there are 2 bushes on each trialling arm ?
im tempted to do mine just cause
Posted: Sat Oct 20, 2012 10:08 pm
Power: 154 rwkw
yeah two on each. $100 for all the bushes iirc. just follow the instructions on the new bushes for install but you need a press. not sure if you can do it without one but i dont think it will be easy.
Posted: Sat Oct 20, 2012 10:21 pm
hopefully a work shop can do it cheap , pfft very doubtful
il end up doing it with a die grinder as you said :)
Ride: BAII Futura
thanks for your comments.
I'll take them to a mate who has a press.
Still not sure what happens if remove both arms at once.
I might support the diff with 2 jacks at both ends instead of one in the middle of the diff housing
Posted: Sat Oct 20, 2012 10:24 pm
ya that will do you still got the shocks holding up the diff etc and if you hold the diff up with 3 jacks that will be extra sufficient
Posted: Sat Oct 20, 2012 10:35 pm
Power: 154 rwkw
if you take both off at once, it give the diff housing a chance to roll and might be a bit of extra work to get the arms back in. i dont think i actually supported the diff when i did mine, just jacked up from the side enough to get the weight off them. if the press doesnt get the outer casings out and you havent got a die grinder (i suggest you buy a cheap one, very handy tool) a hacksaw may do the job but it wont be quick
Posted: Sat Oct 20, 2012 10:41 pm
Power: 154 rwkw
for the extra $50 id grab these http://www.ebay.com.au/itm/FORD-FALCON- ... 416cd8d7c5 just make sure the brass inserts for the bushes comes with it. less hassle and screwing around. and no, not mine and dont know who it is
Posted: Fri Nov 09, 2012 10:00 am
Ride: BAII Futura
All done.
The verdict is a 20ton press won't do the job.
We managed with a much bigger one (the piston is rated at 60T). With the proper fittings to keep the base of the arm flat, they all out went nicely.
Lost few days moking around, in the end with the proper press and tooling it is only a 30 minutes job.
Posted: Fri Nov 09, 2012 10:40 am
Nice very nice looks awesome , hmm seems like every falcon with over 50K km has these bushes absolutely hammered
Users browsing this forum: No registered users and 37 guests
It is currently Mon May 19, 2025 10:47 pm All times are UTC + 11 hours
