FalconIV |
Would Kings Lows to suit EF (and the KYB shocks with them) be interchangable with AU series 2?
TROYMAN |
yes, the front spring and shock assembly will fit in au, ive got the front springs and shocks from my ed in my au, the only thing i noticed was the au sat a touch lower than the ed did. and rear are a direct fit also providing the au is live axle..
FalconIV |
Excellent. Cheers.
Ctchme |
what about ultima front shocks that suit au2? when i had my au most places wouldnt put them in because they were to difficult to fit
_________________ EFII Fairmont (XH00NR) - K & N apollo enclosed pod filter, Megasquirt 2 Ecu controlling fuel, 350 cc injectors flowed out 420cc, Walbro 255lph fuel pump, J3 chip with custom transmittion map, BA XR6 front seats. Turbo setup in the works. |
TROYMAN |
its easier to fit shocks to an au over an e series, so i dont know they say its to hard???
Matt_jew |
They will fit but they are not interchangable on the front. AU springs are longer so the front will sit higher then your expecting.
Live rear axle is the same but.
REW93N |
{USERNAME} wrote: its easier to fit shocks to an au over an e series, so i dont know they say its to hard??? +1
_________________ Blue blooded. |
SWC |
{USERNAME} wrote: They will fit but they are not interchangable on the front. AU springs are longer so the front will sit higher then your expecting. Live rear axle is the same but. Part numbers for King Lows; EA-EL - KFFL-26 Front - KFRL-27 Rear AU - KFFL-57 Front - KFRL-27 Rear Rear are Live Axle of course. |
Ctchme |
thanks for the info guys, might as well sell them then haha
FalconIV |
What about sway bars and rear control links?
I mean If i have aftermarket swaybars and control links on the EF will they go into the AU? |
MAD |
As a complete strut they are totally interchangeable.
I had Eibach AU springs fitted to Pedders Saloon car shocks in my car while I had my Koni's modified to use the Tapered AU springs. The ride height seemed the same to me. |
FalconIV |
{USERNAME} wrote: {USERNAME} wrote: They will fit but they are not interchangable on the front. AU springs are longer so the front will sit higher then your expecting. Live rear axle is the same but. Part numbers for King Lows; EA-EL - KFFL-26 Front - KFRL-27 Rear AU - KFFL-57 Front - KFRL-27 Rear Rear are Live Axle of course. This is a pretty telling sign. Is it the same story up front? |
SWC |
That is front and rear numbers......
