AU Series ll 4.0L BTR 93LE 4 Speed Auto Transmission
 Post subject: AU Series ll 4.0L BTR 93LE 4 Speed Auto Transmission
Posted: Thu Jan 24, 2013 4:33 pm
Ride: 2014 Ford Focus Trend
Hello Members
I have owned a few Falcons over the years XC, XF, EB Series ll and at present an AU Series ll 4.0L Sedan.
I also have rebuilt my own transmissions C4, BW35 Escort Mk 1, BW 40 and years ago Allison 6000 Series and a few Trimatics. I have never had any trouble with the transmissions I have rebuilt.
I have never touched a BTR 93LE, however, because I haven't needed to.
Now my BTR 93LE AU Series ll is playing up. No REVERSE.
From my research, it is probably C3 Clutch.
Has anyone rebuilt one of these ? Dumb question, of Course you have.
Any suggestions Please ?
QUESTIONS
1. Also, there is no Line Pressure tapping on the transmission casing, has anyone modified the transmission casing so as to have an external Line Pressure tapping.
I would have been given the DCM at Detroits for not having a Line Pressure Gauge on the transmission on start up after rebuild. Allision HT 750 Transmission.
2. Has anyone modified the transmission casing so as to have external Front and Rear Band adjustments, instead of the internal adjustment.
HELP Please.
Thankyou in advance.
Kind Regards
meanu
 Post subject: Re: AU Series ll 4.0L BTR 93LE 4 Speed Auto Transmission
Posted: Thu Jan 24, 2013 10:36 pm
Ride: AU XR8
cant help you with the line pressure,
but if you can get a 87le trans (or maybe just the casing) from ea to ed they have external band adjustment and a trans dipstick, but other than some minor differences they are pretty much the same and can be used as a replacement for the 93le,,
Posted: Thu Jan 24, 2013 11:00 pm
Thankyou Troyman for the information.
Kind Regards
meanu
Posted: Sat Jan 26, 2013 12:16 pm
Ride: Ford Falcon AU 2000 Series II
G'day meanu,
I sent you a pm. Did you receive it?
It is currently Wed Jul 09, 2025 11:04 pm All times are UTC + 11 hours
