AU '99 xr6 (1) torque convertor
Page 1 of 1 [ 6 posts ]
 Post subject: AU '99 xr6 (1) torque convertor
Posted: Mon Mar 25, 2013 9:40 pm
Gallery: 5 images
Ride: 1994 EF
Hi guys I plan to put a 1999 AU xr 6 (1) engine into my EF I have read & plan to do all mods "sump" knock sensor & so forth as mentioned on here BUT my question is DO I use my EF torque convertor or do I run the AU one ? any advice most appreciated
cheers
Dino
 Post subject: Re: AU '99 xr6 (1) torque convertor
Posted: Mon Mar 25, 2013 9:48 pm
Gallery: 40 images
Ride: EF GLi/Ghia bitsa
It doesnt matter, AFAIK, they'll be the SAME.
Gab
Posted: Mon Mar 25, 2013 10:00 pm
Ride: AU XR8
ef2 to au normally run the same converter..
Posted: Mon Mar 25, 2013 10:13 pm
Ride: EF Fairmont
Tried to fit an AU convertor to an EFII and it bound up on the crank. May have been an AUIII but not sure. Fitted an EF convertor to an AU motor with no issues.
Posted: Mon Mar 25, 2013 10:21 pm
Ride: AU XR8
generally unless its been changed, the converter/ box from ea 4speed 87le up to ef with dip stick usually have the shorter input on the converter, then the 93le without dipstick up to au3 has the longer input on the converter..
but due to the age of these things now, boxes get swapped and reco'd so best to use the converter thats in the box your going to use..
Posted: Wed Mar 27, 2013 4:42 pm
Gallery: 5 images
Ride: 1994 EF
ok guy's thanks very much for advice
It is currently Sun Jun 22, 2025 5:58 am All times are UTC + 11 hours
