diff seal
Page 1 of 1 [ 10 posts ]
 Post subject: diff seal
Posted: Sat Nov 01, 2014 12:20 pm
Ride: el falcon xr6
Hi all, I have a 98 EL with the diff leaking out of the Centre and spraying the under side of the car
I have had the seal replaced but still does it, any ideas would be great.
 Post subject: Re: diff seal
Posted: Mon Nov 03, 2014 5:14 pm
Ride: el wagon
Probably need to replace the yolk as well. May be grooved.
Posted: Mon Nov 03, 2014 10:35 pm
Ride: 96 XH/97 EL
Where on the yoke is it leaking from ?
Posted: Tue Nov 04, 2014 8:38 pm
Ride: el wagon
The yolk is the part that the universal joint is bolted to. As the car moves, it spins around. Sometimes, over time (and the car is 16 years old, and the diff has spun umpteen million times!!) the seal can create a groove in the yolk "shaft" and this can cause a leak. However, if you had the seal replaced, the mechanic, if he was worth his salt, should have told you that the yolk was grooved, and maybe needed replacing
Posted: Tue Nov 04, 2014 9:26 pm
Ride: EF Fairmont
There is no yoke on the E series diff. Tailshaft bolts to the Rear axle flange which is bolted to the Pinion Shaft. What you have said about wear on the yoke can occur on the pinion shaft.
My guess is that the oil seal on the pinion shaft has not been fitted correctly and has chewed out.
Posted: Tue Nov 04, 2014 9:39 pm
Ride: el wagon
What he said :)
Posted: Tue Nov 04, 2014 10:35 pm
Ride: 96 XH/97 EL
Terminology aside, depends where the leak is coming from - it isn't always the seal.
If the OP makes another visit here one of these days to add more detail, it might be worth giving a more detailed answer.
Posted: Thu Nov 13, 2014 5:51 pm
Ride: el falcon xr6
Cheers for all the replies guys, yeah it doesn't drip out between the dif and flange when sitting still just sprays the bottom of the car when in motion, was told by another mechanic that it needs to be reconditioned as the flange has been disturbed to replace the seal affecting the bearing preload for the spigot shaft (which can only be reset with a new crush washer and the crown wheel removed :shock: )
Posted: Sun Dec 21, 2014 8:45 pm
Gallery: 16 images
Ride: ford ef2 xr6
sounds like first mechanic may have overtightened the flange nut when replacing seal the first time...resulting in a broken crush washer and excessive bearing pre load which will,over time result in bearing failure.
Posted: Tue Dec 23, 2014 5:14 pm
Ride: 93 ED sedan
Power: 161 rwkw
Whether it's a Diff pinion yoke, or drive flange, they have the same idea with where the seal runs.
If it is grooved, it can be fixed with a Speedi-Sleeve, and a new oil seal, on either of them.
Another place oil can leak from is from the Spline.....when the oil seal was replaced, did they put some 567 Loctite on the spline to help seal it....????
This helps a lot.
http://youtu.be/jJTh9F3Vgg0
It is currently Mon May 19, 2025 9:10 pm All times are UTC + 11 hours
