Stripped thread - AU gearbox mount
Page 1 of 1 [ 12 posts ]
 Post subject: Stripped thread - AU gearbox mount
Posted: Thu Jun 11, 2015 3:56 pm
Ride: AU XR8 220 Manual
HI everyone,
I have an AU XR8 which has had a manual conversion. I noticed when dropping the back of the gearbox to do a short shifter installation that I have a problem...
The threads on the gearbox crossmember (passenger side) have been damaged. When I do them up, they wont lock tight, slip on the thread and loosen. It seems the threads have been partially stripped I guess.
My question is what can I do about it? Where do these actually bolt into? THe chasis? Floor?
Could I retap the thread? Any suggestions would be great. Its not a big issue at the moment but will need to be fixed obviously.
Thanks!
 Post subject: Re: Stripped thread - AU gearbox mount
Posted: Thu Jun 11, 2015 10:06 pm
Gallery: 22 images
Ride: AU2 XR8 ute & 91 EA bitsa
IMO you need to tap a thread for a slightly larger hi-tensile bolt. If you go to Total Tools or All Tools, they can supply you with the bolts. Buy a suitable tapered tap off eBay.
AU2 XR8 with Raptor VL, ported Yella Terra GT40P heads, Scorpion 1.6 RRs, XE264HR-14 Comp Cam, ceramic coated Hurricane Headers, 60lb injectors, Walbro 255, 200cfi cats, 3" exhaust & Snow Performance water methanol injection
Posted: Sun Jun 28, 2015 4:19 pm
I finally got to have a look. There is basically a thread inside of the sub frame of the car. These have been stripped...
All I can think of is a tap or a helicoil? Can these threads be accessed from inside the car at all?
Posted: Sun Jun 28, 2015 7:16 pm
helicoil from underneath
the kit will come with the correct tap
the only thing i can think of is the thickness of the metal in the chassis
as you have to drill out the old thread ( with the correct size drill bit ) and then re tap that
RIP SCOTT
Posted: Sun Jun 28, 2015 8:08 pm
I was wondering about that too. I cant find any information on it. There must be a way to fix it. It is very common on alot of cars (google search) just not our falcons.
I also wonder if I could hole saw drill a small hole in the floor and run a whole new high tensile nut and bolt through the hole, removing the thread system all together..
Posted: Sun Jun 28, 2015 8:11 pm
Could I just put some spot welds on the edges of the bracket to the floor and neatly use an angle grinder to remove them if I have to remove the crossmember?
Posted: Tue Jun 30, 2015 6:37 pm
Ride: Fairmont AU I
Seriously i would say just re tap the thread.
A bolt and nut.. just a bad idea.
Welding it.. why?
just tap it
Posted: Tue Jun 30, 2015 9:05 pm
Is there enough material in the floor rail though? That has been a worry of a few people as above.
Posted: Tue Jun 30, 2015 9:22 pm
Ride: Fairmont AU I
Well you won't be drilling that much larger. I think they're m10 bolts or something so just go up to m12 it's only 2mm more radius
Posted: Wed Jul 01, 2015 9:20 am
Yeah thats fair enough. I was told that because it was converted the underfloor structure may be different and therefore less material but no one can confirm it. I agree a retap or helicoil would be nice and easy. Just dont want to risk having them fatigue and fail.
Posted: Wed Jul 01, 2015 9:50 am
Is AU different to EL where there is a 'nut' in the rail that can be replaced?
EL Fairmont Ghia - Manual - Supercharged
- {DESCRIPTION}
- {DESCRIPTION}
Posted: Wed Jul 01, 2015 10:01 pm
If there is a but, I can't see a way to get too it without cutting into the floor skin from the inside.
It is currently Sat Jun 21, 2025 10:13 pm All times are UTC + 11 hours
