Boost'd LOWMont |
Hi everyone,
So i recently did a gearbox swap since my previous auto was smashing into gears. Had a second gearbox which I switched in, all sweet. After 100km, it's starting to not go into gear and will only select after I've given it some revs (around 2k). Though it may have been air pockets after doing swap and have continued to fill the box but its now full and still having the same issue. It will do this when ever I need to slow down. Once in gear, its fine and shifts fine. It's only occurring when its not under power. Does anyone know what may be the problem? Regards, Cameron |
bam1992 |
Age: 33 Posts: 113 Joined: 27th Mar 2014 Ride: ford falcon el xr6 Location: nambucca heads |
maybe torque converter ??
_________________ boosted El xr6, 3 inch exhaust, machined ba 17s, super low king springs,koni shocks, custom regring by wade cams, 5 spd manual, xtreme heavy duty clutch and now much more |
Boost'd LOWMont |
Hey there, I was thinking torque converter but have found that after driving the first 100m, the issue is no longer existent. So its not consistently slipping. It happens after the car has sat for awhile, and therefore I'm thinking its a pressure issue to the torque converter. Possibly the pump? or something else, not sure.
Users browsing this forum: No registered users and 34 guests |
