Turboloverdo |
Im just wondering
Is it possible to run a EF -AU BTR 4 speed in a EA with a 3.9L which came with the Borg warner 3 speed ? Which torque converter and "fly wheel" will i need |
Mad2 |
not 100% sure ... but you will need the EA2 4sp wiring loom for the trans controller [was seperate unit] trans controller, ECU [?]. will most likely need the EA2 converter [?] & flexplate/flywheel unless hole in back of crank same size?? ... had a EB gearbox fitted to a AU so 'shouldn't' be a major problem. don't know if original gearbox mount will work or not. thought about going manual??
Shortshift |
The EA Series 2 came out with a BTR 4 speed. You need to change the ECU. If you use and EL Auto ECU, you wont need a separate Transmission Control Module used in the EA-ED models.
Not sure about the torque converter, but I'd buy both items as a 'package' if possible.
Turboloverdo |
Ive got a complete EF here for parts
I just want to get use out of the current EA 3sp . before using the BTR as i know from what i have read a rear gear box mount "mod" is needed Will be running a EF ECU with a J3 ,so not sure if the Trans control module is needed ? I am just concerned on if the 3 speed will bolt on behind the EA-AU blocks , due to if they fit the EA-AU engines then it shall hopefully defiantly fit onto the back of the BA donk i have waiting here P.s i am an easy driver so it shall last me with 200ish rwkw |
SWC |
If you are using the 3.9l with dizzy, you won't be able to use the EF ECU. It is set up for coil pack, not dizzy.
Turboloverdo |
{USERNAME} wrote: If you are using the 3.9l with dizzy, you won't be able to use the EF ECU. It is set up for coil pack, not dizzy. That is ok i have a EF parts car here dont mind converting to EF coil pack |
Users browsing this forum: Google Adsense [Bot] and 22 guests |
