Using lowering blocks on a bf wagon
Page 1 of 1 [ 7 posts ]
 Post subject: Using lowering blocks on a bf wagon
Posted: Sat Apr 30, 2016 10:27 pm
Ride: Bf wagon
What is the largest size blocks that you can use with 19" rims?
 Post subject: Re: Using lowering blocks on a bf wagon
Posted: Sun May 01, 2016 8:28 am
Ride: EF Fairmont
Depends on how low you want to go.
Has nothing to do with the rim size.
Posted: Sun May 01, 2016 8:41 am
Ride: Bf wagon
Oh, ok. I was told that you could only use lowering blocks on larger size wheels. Thanks.
Posted: Sun May 01, 2016 8:50 am
Ride: EF Fairmont
Who ever told you that is an idiot.
Example:
If the car has a sill clearance of 150mm and you use 2" (50mm) Lowering Blocks the car will come down approx 50mm, giving a sill height of 100mm approx.
Posted: Sun May 01, 2016 12:02 pm
Ride: AU XR8
that is somewhat true, the shock is mounted outward and below the lowering block and can hit the rim on b series wagons and utes.
Posted: Mon May 09, 2016 12:03 pm
Power: 148 rwkw
My son bought a BA with lowering blocks (don't know how big) but the seller kept the 19" wheels that were on it, so my son put a set of factory 17" alloys on it. The lower shock mount cut a nice groove around the inside of the rim :shock: . He had to swap out the lowering blocks for smaller ones to prevent the problem.
Posted: Wed May 11, 2016 4:45 pm
Ride: Bf wagon
Thanks for all the feedback, 2" blocks with 19" rims worked just fine.
Cheers.
It is currently Sat Jun 21, 2025 3:02 am All times are UTC + 11 hours
