FORD V8 to T5 bell housing
 Post subject: FORD V8 to T5 bell housing
Posted: Thu Jun 03, 2010 5:36 pm
Ride: GREEN ED XR6
Power: 249 rwkw
I have a bell housing i bought from the wreckers to put a EFI 302 and T5
A few people here have told me that the bell housing has the starter on the wrong side for aussie 302 EFI but maybe modified to fit Aussie EFI V8 motors but i have bolted both my EA and AU T5 gearboxes to it and fit fine so it maybe a V8 to 6CYL T5 adapter
All I'm asking for it is what I paid for it $250
Hers a few pics I took of it after i cleaned it (had oil on the inside of it)
May Trade for other Falcon parts
Ill get measurements of the bolt holes and length and width up ASAP
Also i have a EFI manual flywheel to go with it too
AU2 engine with Hoppers head/cam performance package & spool rods / CP pistons ,Snort 1200 plenum, T56 Manual & Billet short shifter, Front & Rear Slotted rotors, Pedders lowered suspension, LSD and tuned with EMS stinger 4424 347rwkw THE ED XR6 IS BOOSTED
 Post subject: Re: FS [QLD]: FORD V8 WINDSOR to T5 bell housing
Posted: Thu Jun 03, 2010 5:39 pm
Power: 139 rwkw
Wont work on an E series as it is a bellhousing for a hydraulic clutch.
It is also for an early model motor. It would fit Cleveland too.
Posted: Thu Jun 03, 2010 5:51 pm
Ride: GREEN ED XR6
Power: 249 rwkw
UPDATE
Could be good for a T5 behind a Cleveland conversion
 Post subject: Re: FS [QLD]: FORD V8 to T5 bell housing
Posted: Thu Jun 03, 2010 6:01 pm
Ride: AU XR8
it looks like a clevo bellhousing from an xd or similar??
is a a ford bellhousing or a dellow or crs?? it should be stamped or cast into the housing..
Posted: Thu Jun 03, 2010 6:05 pm
Ride: au/nu series 1 fairlane 6
Looks just like my ford 4 speed borgie to cleveland bell housing which i modded to fit my t5
pretty easy to do .
Posted: Thu Jun 03, 2010 6:57 pm
Ride: GREEN ED XR6
Power: 249 rwkw
dont know if its to suit a 6cyl or an 8 cyl but will have the measurements up soon and it has a ford stamp or numbers on it somewhere ill update after tea
Posted: Thu Jun 03, 2010 7:26 pm
Ride: GREEN ED XR6
Power: 249 rwkw
ok after measuring it up the measurements are as follows
Bell housing depth (from block face to gearbox face) -170mm
Whole diameter in bell housing is 125mm across
The bolt holes for the gearbox are 200mm apart at top (left to right)
and the bottom gearbox holes are 165mm apart (left to right)
It also has no ford markings on it ie (92da etc)
but has this on the gearbox face of the bell housing
ARDIDA 6394FA CAS
looks like its from the casting?
Posted: Thu Jun 03, 2010 7:36 pm
Ride: GREEN ED XR6
Power: 249 rwkw
ARDIDA 6394FA CAS - looks like its from the casting?
Posted: Thu Jun 03, 2010 8:25 pm
Ride: GREEN ED XR6
Power: 249 rwkw
V8 Clevland to T5,
STILL FOR SALE.....
 Post subject: Re: FORD V8 to T5 bell housing
Posted: Sun Jan 23, 2011 4:29 pm
Power: 139 rwkw
Not for a bullnose top loader to suit a big block by any chance?
Posted: Fri Mar 24, 2017 8:04 pm
I know this is old but it's what I'm after, still for sale?
It is currently Sun May 18, 2025 4:02 am All times are UTC + 11 hours
