Rubber hose from Ford AUII Rear Live Axle
 Post subject: Rubber hose from Ford AUII Rear Live Axle
Posted: Sun Aug 20, 2017 2:26 pm
Ride: Ford Falcon AU 2000 Series II
I've noticed rubber hose is starting to crack at the point where it goes onto what I think is the breather pipe of the live axle.
The same hose goes up and is traveling inside the vehicle. I have not traced the rubber hose as yet.
Does anyone know what size this rubber hose and what purpose does it serve?
Heres a pic
 Post subject: Re: Rubber hose from Ford AUII Rear Live Axle
Posted: Sun Aug 20, 2017 7:13 pm
Hi. don't know the size, but it's only use is as a breather for the diff so no water can go in thru that point. the hose finishes an inch or two from where it goes in.
Posted: Sun Aug 20, 2017 10:40 pm
Mad2,
Thanks mate, I wasn't sure if it was connected to anything else when it goes up the hole.
Easy enough job to do then.
Users browsing this forum: No registered users and 51 guests
It is currently Tue May 20, 2025 11:03 am All times are UTC + 11 hours
