XR8 AU II '' Clunking'' in a** end !!
Page 1 of 1 [ 9 posts ]
 Post subject: XR8 AU II '' Clunking'' in a** end !!
Posted: Wed Jul 20, 2005 3:52 pm
i got an XR8 AU II 2001... there is a big '' clunking'' sound in the ars end when you are taking off or just putting around.. i have had the diff rebuild, thinking the star gear had been flogged out. but all was good. i have had the rest of the ars end inspected by ford and diif places and no one has a clue... just wondering if anyone has had a problem the same.. or any idea's for me.. i have spent thounds trying to find this boodly noise.. any help would be great as i am all out of idea's.. cheers
Posted: Wed Jul 20, 2005 4:19 pm
Ride: EL Futura
If its been checked by diff joints its not likely to be this, but I've had a phantom cluck that was loose tail shaft to diff flange bolts
5 Speed EL Futura
Stock as a rock*
A1 Oils - Synthetic lubricants: www.a1oils.com.au
* A rock that has been Alted
Posted: Wed Jul 20, 2005 4:29 pm
Ride: XR6
i got the exact same noise, pisses me off..
AU series 2 XR6 Stock...
For the moment
Posted: Wed Jul 20, 2005 5:05 pm
Ride: EL GT - T2 TS50
Not the exhaust hitting the body? or diff ?
Posted: Wed Jul 20, 2005 5:21 pm
Ride: NC II Fairlane
have you had youe suspention looked at?
reason i say this is that a mate of mine put some new shocks in his bombadoor and had a terrible bang like yours.
reason,he had put both rubbers on the bottom of the shock.
"Looking at cleavage is like looking at the sun. You don't stare at it. It's too risky. You get a sense of it and then you look away."
Now with el thermos fitted.
Posted: Wed Jul 20, 2005 8:02 pm
Ride: TE50
change the diff oil and add some of the anti-chatter additive as per factory specs. Some of the newer diff oils aready have the additive in there, as ford/h*lden have had similar issues with diff clunks. Do a few left hand and right hand full lock slow circles (slow..) to distribute the stuff around. The NEWER Penrite 10/10ths and the 80/140 Castrol SAF-XA have the additives (75/140 saf-xa and earlier Penrite do NOT have the additive, but Penrite do sell the additive seperately.)
Do not dismiss this until you have tried it - I was lucky and did this BEFORE going to a diff place. In slow Peak hour traffic, the clunks were REALLY bad... after treatment as above, its quiet as a mouse.
let us know how you get on.
Posted: Thu Jul 21, 2005 6:51 pm
Ride: AU-XR8
Had the same problem, turned out to be shock mounts were broken. Then the diff got rebuilt and all was good.
She'd be a lot more modded if I didn't have to keep wasting cash on repairs.
 Post subject: problem solved! i think...
Posted: Wed Aug 03, 2005 11:45 am
Took the diff out and back to the bloke who rebuilt it.. he adjusted the
clearence's and said the diff was in perfect condition.. so i though it back in and added some Lx-3 modifier and Castrol LSX-90 and done a few circle's around the yard. not a sound... u can still here it very faintly and does the odd clunk. but has emproved 100%. i don't think this will be the end solution but has solved my problem for now.. thanx
 Post subject: diff backlash
Posted: Wed Aug 03, 2005 10:49 pm
Ride: Typhoon
i wld say the diff has excess backlash get new spaces for it and it should be good as gold
cron
It is currently Fri Jun 20, 2025 3:09 am All times are UTC + 11 hours
