NOCLAF |
My check abs light is comn on quite alot now... what causes it? and how do i fix it...?
_________________ It puts the lotion on its skin.. or else it gets the hose again! |
EB XR8 |
Same problem. I have heard that line-locking f**k up the ABS on cars. I could be wrong though. The EB-ED ABS systems don't have a very good reputation from other owners i have spoken to. Probably not worth worrying about unless you REALLY want ABS (maybe if your driving around kids or whatever).
_________________ 5L, 5 Speed, 2.5" exhaust, 17" EL GT's, GT body kit. Pearl Black. |
NOCLAF |
yeh... it just f**k me off having this bright red light sayn CHECK ABS in ya face all the time.. i was worried at first but once i read in the manual that it doesnt affect your brakes u just wont hav ABS i was to worried just p****d off!
EB XR8 |
Just take out the bulb. Thats what i did.
el_747 |
The EB-ED abs system is s**t your better off with out it. It is most likley you comp stuffed which is common. Just do what i did just pull the globe out until u know what the problem is. When does the abs light come on ?
NOCLAF |
Yeh i hav been thinkn about takn the bulb out.. um it comes on about 20 seconds after i start my car and stays on until i turn my car off...
el_747 |
Hmm have u cleaned the abs sensors ? Give that a go still the same prob might be the computer
Matti |
I just added the EB-ED ABS Diagnostic Page to the site (In the last 5 minutes or so)...
The Diagnostic information should give you some idea what the problem could be.... I have found on the EF/EL Models that the Wheel speed sensors get a LOT of crap built up on them, and they cannot sense the tone wheel. Hence the ABS Module thinks that the wheel is not spinning, and that the wheel is permantly locked up, (even though it has reduced brake pressure to that wheel)... Hence it fails, and shows the warning light. Double check that this is indeed the problem, and if it is, then take the wheel off, and dose the tone wheel, and the sender in some degreaser, and clean the area up.... Most of the time this does fix the problem. Ohh, the EB-ED ABS Diagnostic page is http://www.fordmods.com/phpBB2/documents.php?doc=48
_________________ VE Calais V8, IQ, HSV instruments and brembos fitted. |
NOCLAF |
Oh awsome cheers for that... yeh i cleaned the sensors on the front and never got around to doin the ones on the back so i hope thats it!
Cheers fellas!
Users browsing this forum: No registered users and 20 guests |
