[DELETED-irrelevant]
Page 1 of 1 [ 9 posts ]
 Post subject: [DELETED-irrelevant]
Posted: Sun Jan 15, 2006 11:31 pm
[self-deleted]
Last edited by blackjack_original on Fri Jun 06, 2014 5:24 pm, edited 1 time in total.
Posted: Sun Jan 15, 2006 11:44 pm
Ride: EBII XR6 /ED XR6 /EF XR6
Power: 154 rwkw
theres no problem with a falcon pump, unlike the commodres with a remote reseviour. a dyno run wont cause a pump to leak, but a hot engine bay will. i did rebuild pumps and racks for a couple of years at my last job and can tell you after doing about 1000 vt racks n pumps i only ever fit 2 au racks excluding accident damaged ones.
but if its leaked out that fast its probably a hose, but if not and you rebuild the pump again yourself get a high temp seal kit , should have brown o-rings not black ones.
the belt tension wont cause it to leak providing you didn't leaver on the cannister to get the tension, have seen this done before, bent cannister causing leaks from the rear o-ring.
Posted: Mon Jan 16, 2006 12:07 am
[self-deleted]
Last edited by blackjack_original on Fri Jun 06, 2014 5:26 pm, edited 1 time in total.
Posted: Mon Jan 16, 2006 12:08 am
Power: 154 rwkw
no probs
Posted: Mon Jan 16, 2006 2:56 pm
[self-deleted]
Posted: Mon Jan 16, 2006 4:18 pm
Ride: el faimont, dual fuel
that is the high preassure hose, the stell hose has an o ring on it and it connects, clicks in, to the big bolt which has another oring on it and it srews into the pump.
your best of getting it rebuilt by hose place, or getting a new one, pricey though. as the internal oring usually goes once you take it off a couple of times.
i don't know why it crumbled.
why do u write in here.
Posted: Mon Jan 16, 2006 4:40 pm
[self-deleted]
Posted: Mon Jan 16, 2006 5:11 pm
Power: 154 rwkw
best to flush the system if pieces of the o-ring is in there, the big bolt you refer to part of the valve, then there is the spring and then the valve. the valve has a small, fine gauze filter on it and can get blocked by the smallest things. when it gets blocked you will notice your steering getting heavier until it doesn't work again. you can use dex111 fluid in those systems but ford uses a clear fluid, dear as poison from ford, but i use fuchs utto 1220 or 1240 or something can't quite remember at the minute. same stuff but is a cheaper option.
Posted: Mon Jan 16, 2006 5:50 pm
Ride: No Fords current
When my pump was leaking it turned out to actually not be the pump, just the high pressure hose.
Users browsing this forum: No registered users and 68 guests
It is currently Fri Jun 06, 2025 1:31 pm All times are UTC + 11 hours
