Knocking noise when turning.
Page 1 of 1 [ 6 posts ]
 Post subject: Knocking noise when turning.
Posted: Fri Feb 24, 2006 8:33 pm
Gallery: 20 images
Ride: ef/el halfbreed
I have this problem with the front end, when i turn a corner when braking i hear a knock come from the front of the car. Any thoughts?
Destroy everything and dont look back!!!!!!
94 ef-el-xr-fairmont. No idea anymore.
Posted: Fri Feb 24, 2006 9:44 pm
Ride: LS3 VF
check all bushes etc, and also run a spanner over all the bolts u can see under the front end.. failing that id suggest maybe upper ball joint? ive seen a few of them go
Posted: Fri Feb 24, 2006 9:55 pm
Gallery: 20 images
cool thanks dude i'll try that.
Posted: Sat Feb 25, 2006 4:33 pm
Ride: 2009 FG XR6 Sedan
I had the same problem, would clunk only whilst turning under brakes. Wheel bearings had to be adjusted as they had to much end float.
Posted: Sat Feb 25, 2006 8:03 pm
Ride: Ford FPV FG F6 310
Power: 149 rwkw
check sway bar bushes, i pop 1 every now and again, and thats' how i know it's gone.
Posted: Mon Feb 27, 2006 7:46 pm
just diagnosed that noise last week with my mechanic its the wheel bearings, if u jack the car up and pull the wheel off you will be able to notice the free play in the rotor...
Users browsing this forum: No registered users and 42 guests
It is currently Sun Jun 08, 2025 12:21 am All times are UTC + 11 hours
