Grinding Rotors?
Page 1 of 1 [ 7 posts ]
 Post subject: Grinding Rotors?
Posted: Tue Jan 11, 2005 12:42 pm
Ride: XR6T
Hey People.
My brake pads need changing, but I have also found the Rotors (DBA Slotted) are causing my steering to sudder when I brake.
Im thinking they need to be Grinded.
Now I realize that if they are under 22mm then they cant be done (im yet to measure) But if they are over min thickness, is it a good idea to grind them or is it better to replace the whole rotor??
I dont have that much $$ so If grinding is ok, ill take that route, just want to be sure im doing the right thing before i pay some mechanic to do it....
Cheers,
Adam
"This is FORD country.... Where on a quiet day you can hear the HOLDENS rusting...."
Posted: Tue Jan 11, 2005 12:59 pm
Ride: BA Fairlane Ghia
Machining is fine for them, as you say, if they are within tolerance, i have the same prob with slotteds, vibrates between 80 and 110, but i can live with ti fo rthe time being.
Gallery: 37 images
Ride: V8 EF Futura
Nothing wrong with machining rotors at all - should be able to do it 2 or 3 times in the life of a disc.
Just make sure when they are done u are still above minimum thickness. And remember the thinner the rotor the easier it will be to warp it again.
Posted: Tue Jan 11, 2005 1:09 pm
Ride: XR6T
Thanks guys.
I was just unsure if it was okay to do this with "Slotted" Rotors.
Ive had normal rotors ground before, but not this type.
But hey - if it saves some $$ Ill give it a go b4 throwing away more money for new rotors....
Posted: Tue Jan 11, 2005 4:38 pm
Mate I've got DBA golds on the front of my falc and its not a problem getting the ground. Just like a normal disc. Obviously there is the minimum thickness aspect to it.
Cheers,
David
As an aside, I'd probably go slotted front and back for my next set, the golds look good, but well you know.....
 Post subject: Re: Grinding Rotors?
Posted: Tue Jan 11, 2005 6:53 pm
Ride: Falcon Panelvan
your car is only a few years old, i doubt the rotors will be anywhere near the minimum thickness .. my mates xr just got done, was around $80 all up.
Posted: Wed Jan 12, 2005 9:40 am
Ride: XR6T
Thanks heaps for the replys people.
I have booked the beast in this Friday. So hopefully no dramas and shouldnt cost too much :)
Thanks again,
Adz
It is currently Sun May 18, 2025 3:39 pm All times are UTC + 11 hours
