bArNsY |
Sorry if this has been covered before
I have just brought a Apr 1990 N/A fairlane, I was wondering what sort of diff came standard. I have read a brochure on the N/A fairlane and said it came standard with LSD. Also it has valour trim, I thought only the N/C came with the velour trim. It also has a 4spd auto! Are there numbers or lettering on the diff that can tell me whether it’s LSD or a single spinner? I may be selling parts off it as it’s not worth restoring Any help will be greatly appreciated Adam
_________________ FG G6E Turbo |
NAfairlane... |
We have twins..... Later NA's have 4spd's and velour and as far as i know a 2.92 lsd diff atleast thats what ive been told
_________________ Mercedes 500SEC: -- GONE -- {DESCRIPTION} |
bArNsY |
I have an 1994 ED futura, is it worth putting the fairlane LSD diff in mine?
smiley235 |
yes, if the gears are higher on the ED.
_________________ 178.3 rwkw
kezz |
no. dont do it!
bArNsY |
{USERNAME} wrote: no. dont do it!
can you elaborate why not?
bArNsY |
bArNsY |
wont a 2.92 diff give me slower acceleration? than a 3.11 or 3.23 whatever mine is?
smiley235 |
yes, *waits for kezzaz elaboration*
fordzatmyplace |
{USERNAME} wrote: Sorry if this has been covered before
I have just brought a Apr 1990 N/A fairlane, I was wondering what sort of diff came standard. I have read a brochure on the N/A fairlane and said it came standard with LSD. Also it has valour trim, I thought only the N/C came with the velour trim. It also has a 4spd auto! Are there numbers or lettering on the diff that can tell me whether it’s LSD or a single spinner? I may be selling parts off it as it’s not worth restoring Any help will be greatly appreciated Adam your NA is a series 2 so it would have a 3.23 LSD or the optional 3.27 if your lucky
_________________ ^^^ What He Said
kezz |
yeh why should you put a taller ratio in the car when the ED has a 3.08 or 3.27 or whatever the hell. it would pay to whack an lsd in it though
kezz |
oh yeh, that is assuming it is a 2.92
bigbell351 |
i fitted a 3.23 lsd from an na fairlane to mine 2 weeks ago, but the problem you will have fitting to an ed is, i've been told the trailing arms on the eb-d's are wider than the ea-na ones so this may give you issues. but depending on your ratio it is well worth doing. i went from a 2.77 to 3.23 and made a huge improvement
Sturmovik |
{USERNAME} wrote: My current diff says
"94" in a circle 311 0578-039902 M That means nothing, check the tags that are on it.
_________________ 1993 ED XR6 5speed Polynesian Green. Project car. |
emjay |
chuck a skid if they both light up you got an lsd, just because it says high performance on the tag dont mean you got an lsd my xr8 looked the same as my ef fairmont ghia v8 and the fairmont was a single spinner
Users browsing this forum: Google Adsense [Bot] and 63 guests |
